Dim/Redim
Started by Petrus Vorster, June 04, 2023, 04:15:08 PM
Hi All
I am trying to create a shared Dynamic Array in Freebasic.
It seems a bit different than Powerbasic.
In PB I used to do this:
Global MYlabelsarray()As String
This was declared outside of a procedure, then in a function I would assign values:
Dim MYlabelsarray (1 To myqty&)As String
I tried using COMMON shared MYlabelsarray() as string and redim it inside a procedure.
This works fine between all functions for e.g. Form1, but how do I make it accessable over the entire project?
If i use the same request e.g. print myarray(1) in form2 etc, it tells me the variable has not been declared.
How would you do this in Freebasic?
-Regards, Peter
-Regards
Peter
Here is how you can do it:
dim shared MYlabelsarray() as string
function myfunction1() as long
   dim as long myqty = 100
   redim MYlabelsarray (1 To myqty) As String
   ' or use redim preserve to not destroy existing data in the array
   ' redim preserve MYlabelsarray (1 To myqty) As String
   for i as long = 1 to myqty
      MYlabelsarray(i) = "Label " & i
   next
   function = 0
end function
function myfunction2() as long
   ' Display the global array strings
   for i as long = lbound(MYlabelsarray) to ubound(MYlabelsarray)
      print MYlabelsarray(i)
   next
   function = 0
end function
myfunction1
myfunction2
print
print "Press any key to exit..."
sleep
Hi Paul
Thank you, that was what i did eventually.
It works fine in all the procedures under form1, but as soon as i try and refer to the array for procedures on another form, I am getting that "variable not declared".
So i just moved all the functions that would use the Array to form1. -Problem solved.
I wonder if it doesn't have something to do with the fact that i am using child forms on a tab-control?
But, problem solved.
Thanks a million.
-Regards Peter
-Regards
Peter
