COM port communications
Started by Petrus Vorster, October 09, 2023, 06:30:19 AM
Hi All
If you have a COM port printer, that uses IPL or ZPL commands, how would you create a loop to intercept the return messages?
From my reading, it uses a standard open "COM1: etc etc" to set parity and send a string to the port.
It works in simple TEXT commands. e.g. "^L ^E Print 'HALLO'"
And another text command to end the label.
There will be a return message e.g. 1 = Done, 2 Error etc.
You need to SEND a message to the printer, then WAIT for the return message.
I have never worked with COM port commands before.
Also, I needs not to clash with anything in WinFBE.
Some pointers will be appreciated.
-Peter
-Regards
Peter
