DDT : statusbar problems...
Started by docroger, July 30, 2025, 02:23:36 PM
docroger
Hello José... me again...
And with DDT again...
If i create a dialog non overlapped (not redim) and a statusbar : the statusbar has always the resize handle draw.
Second problem :
If i create a statusbar (first) and a menu (second), the statusbar is not visible.
' // Create a new dialog using dialog units
   DIM hDlg AS HWND = DialogNew(0, "Bio", , , 200, 200, WS_CAPTION OR WS_SYSMENU OR DS_3DLOOK OR WS_MINIMIZEBOX or DS_CENTER)
   ' // Add a button to the dialog
   ControlAddButton, hDlg, IDC_OK, "&Ok", 105, 40, 50, 12, BS_DEFPUSHBUTTON
    CONTROLADDSTATUSBAR, hDlg, SBAR, "", 75, 105, 45, 15
    STATUSBARSETPARTS hdlg,sbar,"120,-1"
   dim hmenu as hmenu=MENUNEWBAR
  dim hpopup1 as hmenu = MENUNEWPOPUP
   MENUADDPOPUP hMenu, "&Options", hPopup1, MF_ENABLED
   MENUADDSTRING hpopup1, "Exit",id_quit,MF_ENABLED
  menuattach hmenu,hdlg
  'CONTROLADDSTATUSBAR, hDlg, SBAR, "", 75, 105, 45, 15
  'STATUSBARSETPARTS hdlg,sbar,"120,-1"
Sorry for use DDT, but its very easy to port Powerbasic code with it...
The size grip has nothing to do with overlapped or not overlapped dialogs. ControlAddStatusBar sets it by default. If you don't want it then specify the styles that yu want.
ControlAddStatusBar, hDlg, SBAR, "", 75, 105, 45, 15, WS_VISIBLE OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS OR CCS_BOTTOM
docroger
docroger
Hello José,
Maybe a problem with statusbar (with DDT)...
With this code the statusbar is not visible :
'#TEMPLATE DDT Dialog with a button
#define UNICODE
#define _WIN32_WINNT &h0602
#include once "AfxNova/DDT.inc"
USING AfxNova
   END wWinMain(GetModuleHandleW(NULL), NULL, wCommand(), SW_NORMAL)
DECLARE FUNCTION DlgProc (BYVAL hDlg AS HWND, BYVAL uMsg AS DWORD, BYVAL wParam AS DWORD, BYVAL lParam AS LPARAM) AS INT_PTR
CONST IDC_OK = 1001
const sbar = 1002
const id_quit=1003
' Main
   ' // Set process DPI aware
   AfxEnableVisualStyles
   'DIM hDlg AS HWND = DialogNew(0, "DDT Dialog with a button", 50, 50, 175, 65, WS_OVERLAPPEDWINDOW OR DS_CENTER)
   DIM hDlg AS HWND = DialogNew(0, "DDT Dialog statusbar not visible... :(", , , 175, 200, WS_CAPTION OR WS_SYSMENU or DS_CENTER)
     CONTROLADDSTATUSBAR, hDlg, SBAR, "", 75, 105, 45, 15, WS_VISIBLE OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS OR CCS_BOTTOM
  'CONTROLADDSTATUSBAR, hDlg, SBAR, "", 75, 105, 45, 15, WS_VISIBLE OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS OR CCS_BOTTOM
   ' // Anchor the button to the bottom and the right side of the dialog
   ControlAnchor(hDlg, IDC_OK, AFX_ANCHOR_BOTTOM_RIGHT)
   ' // Display and activate the dialog as modal
   DialogShowModal(hDlg, @DlgProc)
   RETURN DialogEndResult(hDlg)
' Dialog callback procedure
   SELECT CASE uMsg
      CASE WM_INITDIALOG
         RETURN TRUE
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN
                  SendMessageW hDlg, WM_CLOSE, 0, 0
            CASE IDC_OK
               MsgBox("OK button pressed", MB_ICONEXCLAMATION OR MB_TASKMODAL, "Message")
      CASE WM_CLOSE
         ' // End the application
         DialogEnd(hDlg)
   RETURN FALSE
and with this code : all is OK :
#define UNICODE
USING AfxNova
CONST IDC_OK = 1001
const sbar = 1002
const id_quit=1003
' Main
   DIM hDlg AS HWND = DialogNew(0, "DDT Dialog statusbar visible... ;)", , , 175, 200, WS_CAPTION OR WS_SYSMENU or DS_CENTER)
    ' CONTROLADDSTATUSBAR, hDlg, SBAR, "", 75, 105, 45, 15, WS_VISIBLE OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS OR CCS_BOTTOM
   SELECT CASE uMsg
      CASE WM_INITDIALOG
         RETURN TRUE
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_OK
      CASE WM_CLOSE
         DialogEnd(hDlg)
   RETURN FALSE
If statusbar is defined before menu : not visible. Normal ?
It is shown, but the heigth size is tiny. Probably one of these pesky caprices of the dialog engine. Add ControlAnchor, that will position the Status bar where it should. Please notice that the values of x, y, width, height aren't used for anything.
CONTROLADDSTATUSBAR, hDlg, SBAR, "", 0, 0, 0, 0, WS_VISIBLE OR WS_CLIPCHILDREN OR WS_CLIPSIBLINGS OR CCS_BOTTOM
ControlAnchor(hDlg, SBAR, AFX_ANCHOR_BOTTOM_WIDTH)
