Edit autoselect problem... maybe
Started by docroger, September 12, 2025, 11:02:40 AM
docroger
Hello José,
Me again... Sorry.
In the cw_edit_autoselect.bas there is no autoselect, maybe the code is faulty :
CASE EN_SETFOCUS
                  ' Note: To deselect, use EM_SETSEL, -1, 0
                  CASE IDC_EDIT1
                     Edit_SetSel(GetDlgItem(hWnd, IDC_EDIT1), 0, -1)
                  CASE IDC_EDIT2
                     Edit_SetSel(GetDlgItem(hWnd, IDC_EDIT2), 0, -1)
I change the code with :
            case idc_edit2
                if cbctlmsg(wparam,lparam)=en_setfocus then
            case idc_edit1
                'sendmessage(GetDlgItem(hWnd, IDC_EDIT1),em_setsel,0,-1)
Seems to work with edit2, but not with edit1.
Maybe its not possible with single line edit...
Maybe iam wrong.
Yes, the code must be:
      ' // Sent when the user selects a command item from a menu, when a control sends a
      ' // notification message to its parent window, or when an accelerator keystroke is translated.
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN SendMessageW(hwnd, WM_CLOSE, 0, 0)
            CASE IDC_EDIT1
               IF CBCTLMSG(wParam, lParam) = EN_SETFOCUS THEN
            CASE IDC_EDIT2
         RETURN 0
New template: https://github.com/JoseRoca/AfxNova/blob/main/SDK%20Templates/CW_Edit_Autoselect.bas
Thanks for reporting it and sorry for the inconvenience.
