AfxNova progress
Started by José Roca, November 14, 2025, 11:37:56 PM
docroger
Hello José,
On the docs, windows, windows gui, menu procedures, there are lines in double and maybe some mistakes with check menu and append menu :
Quote| **AppendMenu** | Appends a new item to the end of the specified menu bar, drop-down menu, submenu, or shortcut menu. |
| **CheckMenuItem** | Appends a new item to the end of the specified menu bar, drop-down menu, submenu, or shortcut menu. |
| **CheckMenuItem** | Sets the state of the specified menu item's check-mark attribute to either selected or clear. |
| **CheckMenuRadioItem** | Checks a specified menu item and makes it a radio item. |
| **CreateMenu** | Creates a menu. |
| **CreatePopupMenu** | Creates a drop-down menu, submenu, or shortcut menu. |
| **GetMenuString** | Copies the text string of the specified menu item into the specified buffer. |
| **GetSubMenu** | Retrieves a handle to the drop-down menu or submenu activated by the specified menu item. |
| **GetSystemMenu** |Enables the application to access the window menu (also known as the system menu or the control menu) for copying and modifying. |
The docs files are very useful and afxnova very good !
Thanx for hard work.
Thanks very much. I will check it. It is a problem of copy and paste. You copy a line to keep the fomatting and change the text, and sometimes you get distracted and forget to change it. Documentation is the worst part. Nobody likes to do it, but I make the effort of documenting all my code. A documentation like the one for GDI+, with 600+ functions, is very hard to do without doing some mistakes.
I have removed the duplicated lines. Thanks again.
I'm wrapping now XmlLite, to have a fast parser and writer for the XML format. I'm now in the phase of the documentation.
#20
Static classes
A practical design choice rooted in how Win32 actually works.
Windows standard controls — BUTTON, EDIT, LISTBOX, etc. — are not object‑oriented. They are handle‑based, message‑driven window classes created by the OS.
This means:
- Windows owns the control
- You interact with it through an HWND
- All operations happen through messages and APIs
- The control can be accessed from anywhere as long as you have the handle
- Trying to wrap this model in strict OOP creates more problems than it solves.
AfxNova's static classes embrace the Win32 model instead of fighting it.
Classic OOP pain points:
- Where do I store the object?
- How do I access the control from a callback?
- How do I map HWND → object?
- What happens when the control is destroyed?"
A static class in AfxNova:
- does not need an instance
- does not track lifetime
- does not require storing objects
- works directly with the HWND
- can be called from anywhere
- matches the Win32 philosophy exactly
Example:
CButton.SetIcon(hButton, hIcon)
CButton.Enable(hButton)
CButton.SetText(hButton, "OK")
This is clean, predictable, and 100% compatible with how Windows expects you to work.
Why static classes are beneficial
Static classes let you group all related functionality in one place, instead of scattering macros and procedures across multiple files. They also allow the use of overloaded methods, making the API easier and more intuitive to use.
As a proof-of-concept, I have implemented CButton, a static class that wraps the functionality of a Button control. It is available at https://github.com/JoseRoca/AfxNova/blob/main/AfxNova/CButton.inc
This shows how a static class can group all related functionality in one place, provide overloads for ease of use, and remain fully compatible with the native Win32 handle‑based model.
These classes aren't limited to Windows controls — the same approach can be used to wrap other WinAPI technologies as well.
With the help of my OLE Container (CAxHost), I have managed to get several of the old VB6 ActiveX controls (OCXs) to work with CWindow.
One of the most interesting is the Microsoft Hyerarchical Grid Control. It works wonderfully with CWindow, my ADO classes and the Jet Database, that comes pre-installed in Windows.
The only limitation is that it is 32-bit only.
This is one of my tests:
' Microsoft Windows
' Contents: Embedded Microsoft Hierarchical Grid Control
' Copyright (c) 2026 José Roca. Freeware. Use at your own risk.
#define UNICODE
'#define _CAXH_DEBUG_ 1
#INCLUDE ONCE "AfxNova/AfxCOM.inc"
#INCLUDE ONCE "AfxNova/CAxHost.inc"
#INCLUDE ONCE "AfxNova/MSHFlexGrid.inc"
#INCLUDE ONCE "AfxNova/CADODB.inc"
USING AfxNova
   END wWinMain(GetModuleHandleW(NULL), NULL, wCommand(), SW_NORMAL)
' // Forward declaration
CONST IDC_GRID = 1001
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Creates the main window
   DIM pWindow AS CWindow
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Microsoft Hierarchical Flex Grid", @WndProc)
   pWindow.SetClientSize(800, 450)
   ' // Centers the window
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\MSHFLXGD.OCX"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_GRID, wszLibName, AFX_CLSID_MSHFlexGrid, _
       AFX_IID_IMSHFlexGrid, RTLKEY_MSHFlexGrid, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   pWindow.AnchorControl(IDC_GRID, AFX_ANCHOR_HEIGHT_WIDTH)
   SetFocus pHost.hWindow
   DIM pGrid AS CMSHFlexGrid = pHost.OcxDispObj
   ' // Set the width of the columns (in twips)
   pGrid.ColWidth(0) = 300
   pGrid.ColWidth(1) = 1100
   pGrid.ColWidth(2) = 3000
   pGrid.ColWidth(3) = 2000
   pGrid.ColWidth(4) = 2000
   pGrid.ColWidth(5) = 3000
   pGrid.ColWidth(6) = 1500
   pGrid.ColWidth(7) = 700
   pGrid.ColWidth(8) = 1200
   pGrid.ColWidth(9) = 1200
   pGrid.ColWidth(10) = 1500
   pGrid.ColWidth(11) = 1500
   ' Change the foreground and background colors
   pGrid.ForeColor = BGR(0, 0, 0)
   pGrid.BackColor = BGR(255,255,235)
   ' Open an ADO connection
   DIM pConnection AS CAdoConnection PTR = NEW CAdoConnection
   pConnection->ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & ExePath & $"\nwind.mdb"
   pConnection->Open
   ' Open a recordset
   DIM pRecordset AS CAdoRecordset PTR = NEW CAdoRecordset
   DIM dvSource AS DVARIANT = "SELECT * FROM Customers"
   pRecordset->Open(dvSource, pConnection, adOpenKeyset, adLockOptimistic, adCmdText)
   ' Set the Datasource property of the recordset
   pGrid.DataSource = cast(ANY PTR, pRecordset->DataSource)
   ' Close the recordset
   pRecordset->Close
   ' Close the connection
   pConnection->Close
   ' // Delete the recordset
   Delete pRecordset
   ' // Delete the connection
   Delete pConnection
   ' // Display the window
   ShowWindow(hwndMain, nCmdShow)
   UpdateWindow(hwndMain)
   DIM uMsg AS MSG
   WHILE (GetMessageW(@uMsg, NULL, 0, 0) <> FALSE)
      IF AfxCAxHostForwardMessage(GetFocus, @uMsg) = FALSE THEN
         IF IsDialogMessageW(hwndMain, @uMsg) = 0 THEN
            TranslateMessage(@uMsg)
            DispatchMessageW(@uMsg)
   WEND
   FUNCTION = uMsg.wParam
' Main window procedure
   SELECT CASE uMsg
      ' // If an application processes this message, it should return zero to continue
      ' // creation of the window. If the application returns –1, the window is destroyed
      ' // and the CreateWindowExW function returns a NULL handle.
      CASE WM_CREATE
         AfxEnableDarkModeForWindow(hwnd)
         RETURN 0
      ' // Theme has changed
      CASE WM_THEMECHANGED
         RETURN 0
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
    CASE WM_DESTROY
         PostQuitMessage(0)
Notice that instead of pWindow.DoEvents I'm using a message pump:
   DIM uMsg AS MSG
   WEND
In it, AfxCAxHostForwardMessage gives the hosted grid to process keyboard messages.
With some tweaking, we can simulate the fashionable dark mode:
   ' // Scroll bars dark theme
   SetWindowTheme(pGrid.hwnd, "DarkMode_Explorer", NULL)
   ' // Change the foreground and background colors
   pGrid.ForeColor = RGB_WHITE
   pGrid.BackColor = RGB_BLACK
   ' // change the color of the background of the grid
   pGrid.BackColorBkg = RGB_BLACK
   ' // Change the colors of the fixed parts of the grid
   pGrid.ForeColorFixed = RGB_WHITE
   pGrid.BackColorFixed = BGR(90, 90, 90)
   ' // Color of the grid
   pGrid.GridColor = RGB_GRAY
   pGrid.GridLines = flexGridFlat
   pGrid.GridColorHeader = RGB_GRAY
   pGrid.GridLinesFixed = flexGridFlat
#23
I have started to write headers to add support for Direct2D in AfxNova. One of the main goals was to allow to use this technology with my graphic control, that now supports GDI, GDI+, OpenGL (classic) and Direct2D. I will also write headers for Direct Write and WIC (Windows Image Component).
This is a preliminary test drawing a circle, using Direct2D, in an instance of the grapic control.
' Microsoft Windows
' Contents: D2D1 - Draw ellipse
#INCLUDE ONCE "AfxNova/CWindow.inc"
#INCLUDE ONCE "AfxNova/CGraphCtx.inc"
#include once "AfxNova/AfxD2D1.bi"
USING AfxNova
CONST IDC_GRCTX = 1001
' This function draws Direct2D content to a GDI HDC.
' hMemDC = Handle of the memory device context of the graphic control
' nWidth = Width of the virtual buffer of the graphic control
' nHeight = Height of the virtual buffer of the graphic control
FUNCTION RenderScene (BYVAL hMemDC AS HDC, BYVAL nWidth AS LONG, BYVAL nHeight AS LONG) AS HRESULT
   DIM hr AS HRESULT
   DIM pFactory AS ID2D1Factory PTR                ' // ID2D1Factory interface
   DIM pRenderTarget AS ID2D1DCRenderTarget PTR    ' // ID2D1DCRenderTarget interface
   DIM pBrush AS ID2D1SolidColorBrush PTR          ' // ID2D1SolidColorBrush interface
   ' // Create an instance of the ID2D1Factory interface
   hr = D2D1CreateFactory(D2D1_FACTORY_TYPE_SINGLE_THREADED, IID_ID2D1Factory, BYVAL NULL, pFactory)
   IF hr <> S_OK THEN RETURN hr
   ' // Get the DPI values
   DIM AS SINGLE dpix, dpiY
   pFactory->GetDesktopDpi(dpiX, dpiY)
   ' // Poperties of the tender target
   DIM props AS D2D1_RENDER_TARGET_PROPERTIES = D2D1_RenderTargetProperties ( _
       D2D1_RENDER_TARGET_TYPE_DEFAULT, _
       D2D1_PixelFormat(DXGI_FORMAT_B8G8R8A8_UNORM, D2D1_ALPHA_MODE_IGNORE), _
       dpiX, dpiY, _
       D2D1_RENDER_TARGET_USAGE_NONE, D2D1_FEATURE_LEVEL_DEFAULT)
   ' // Create a DC render target.
   hr = pFactory->CreateDCRenderTarget(props, pRenderTarget)
   IF hr <> S_OK THEN
      pFactory->Release
      RETURN hr
   ' // Get the dimensions of the graphic control drawing area.
   DIM rc AS RECT = (0, 0, nWidth, nHeight)
   ' // Bind the DC to the DC render target.
   hr = pRenderTarget->BindDC(hMemDC, rc)
   ' // Create a brush.
   hr = pRenderTarget->CreateSolidColorBrush(D2D1_ColorF(D2D1_Blue), BYVAL NULL, pBrush)
   ' // The ID2D1RenderTarget.BeginDraw method signals the start of drawing.
   pRenderTarget->BeginDraw
      ' // The ID2D1RenderTarget.Clear method fills the entire render target with a
      ' // solid color. The color is given as a D2D1_COLOR_F structure.
      pRenderTarget->Clear(D2D1_ColorF(D2D1_White))
      ' // Sample code: Draws an ellipse (replace it with your drawing operations)
      DIM tEllipse AS D2D1_ELLIPSE = (D2D1_Point2F(150, 150), 100, 100)
      pRenderTarget->DrawEllipse(tEllipse, cast(ID2D1Brush PTR, pBrush), 3)
   ' // The BeginDraw, Clear, and DrawEllipse methods all have a void return type.
   ' // If an error occurs during the execution of any of these methods, the error
   ' // is signaled through the return value of the EndDraw method.
   ' // The EndDraw method signals the completion of drawing for this frame.
   ' //  All drawing operations must be placed between calls to BeginDraw and EndDraw.
   hr = pRenderTarget->EndDraw
   ' // Clean resources
   D2D1_SafeRelease(pBrush)
   D2D1_SafeRelease(pRenderTarget)
   D2D1_SafeRelease(pFactory)
   FUNCTION = hr
' Main
   ' // Initializa the COM library
   CoInitialize NULL
   AfxEnableVisualStyles
   DIM pWindow AS CWindow = "MyClassName"   ' Use the name you wish
   DIM hWin AS HWND = pWindow.Create(NULL, "D2D1 - Draw ellipse", @WndProc)
   pWindow.SetClientSize(300, 300)
   pWindow.Center
   ' // Set the main window background color
   pWindow.SetBackColor(RGB_WHITE)
   ' // Add a graphic control
   pGraphCtx.Clear RGB_FLORALWHITE
   ' // Anchor the control
   pWindow.AnchorControl(pGraphCtx.hWindow, AFX_ANCHOR_HEIGHT_WIDTH)
   ' // Draw the graphics
   RenderScene(pGraphCtx.GetMemDc, pGraphCtx.GetVirtualBufferWidth, pGraphCtx.GetVirtualBufferHeight)
   ' // Uninitialize the COM library
   CoUninitialize
   SELECT CASE uMsg
      CASE WM_CREATE
         RETURN 0
         RETURN 0
      ' // Sent when the user selects a command item from a menu, when a control sends a
      ' // notification message to its parent window, or when an accelerator keystroke is translated.
      CASE WM_COMMAND
            CASE IDCANCEL
               IF CBCTLMSG(wParam, lParam) = BN_CLICKED THEN SendMessageW(hwnd, WM_CLOSE, 0, 0)
         RETURN 0
      CASE WM_DESTROY
         PostQuitMessage(0)
         RETURN 0
The graphic control features persistence, double buffering and automatic scrolling.
Direct2D offers higher quality and speed than GDI+, and is better suited for working with high-resolution monitors. So it seems the time has come to transition to a more advanced technology.
' Microsoft Windows
' Contents: D2D1 - Radial gradient brush
USING AfxNova
   DIM hr AS HRESULT
       dpiX, dpiY, _
   IF hr <> S_OK THEN
      pFactory->Release
      RETURN hr
      ' Bézier heart with radial gradient fill + glowing border + gold outline
      ' // 1) Radial gradient for the heart fill
      DIM pFillBrush  AS ID2D1RadialGradientBrush PTR
      DIM pFillStops  AS ID2D1GradientStopCollection PTR
      DIM fillStops(3) AS D2D1_GRADIENT_STOP
      fillStops(0).position = 0.0
      fillStops(0).color    = D2D1_ColorF(1.0, 0.95, 0.6, 1.0)   ' warm highlight
      fillStops(1).position = 0.33
      fillStops(1).color    = D2D1_ColorF(1.0, 0.6, 0.2, 1.0)    ' orange
      fillStops(2).position = 0.66
      fillStops(2).color    = D2D1_ColorF(0.4, 0.3, 1.0, 1.0)    ' violet
      fillStops(3).position = 1.0
      fillStops(3).color    = D2D1_ColorF(0.1, 0.1, 0.3, 1.0)    ' deep blue
      pRenderTarget->CreateGradientStopCollection (fillStops(0), 4, D2D1_GAMMA_2_2, D2D1_EXTEND_MODE_CLAMP, pFillStops)
      DIM fillProps AS D2D1_RADIAL_GRADIENT_BRUSH_PROPERTIES
      fillProps.center = D2D1_Point2F(175, 150)
      fillProps.gradientOriginOffset = D2D1_Point2F(-60, -40)
      fillProps.radiusX = 180
      fillProps.radiusY = 120
      pRenderTarget->CreateRadialGradientBrush (fillProps, BYVAL NULL, pFillStops, pFillBrush)
      ' // 2) Glow border (soft halo)
      DIM pGlowBrush AS ID2D1RadialGradientBrush PTR
      DIM pGlowStops AS ID2D1GradientStopCollection PTR
      DIM glowStops(2) AS D2D1_GRADIENT_STOP
      glowStops(0).position = 0.0
      glowStops(0).color    = D2D1_ColorF(1.0, 1.0, 0.9, 1.0)   ' bright glow
      glowStops(1).position = 0.6
      glowStops(1).color    = D2D1_ColorF(1.0, 0.6, 0.2, 0.4)   ' soft orange
      glowStops(2).position = 1.0
      glowStops(2).color    = D2D1_ColorF(0.0, 0.0, 0.0, 0.0)   ' fade to transparent
      pRenderTarget->CreateGradientStopCollection( _
         glowStops(0), 3, _
         D2D1_GAMMA_2_2, _
         D2D1_EXTEND_MODE_CLAMP, _
         pGlowStops)
      DIM glowProps AS D2D1_RADIAL_GRADIENT_BRUSH_PROPERTIES
      glowProps.center = D2D1_Point2F(175, 150)
      glowProps.gradientOriginOffset = D2D1_Point2F(0, 0)
      glowProps.radiusX = 210
      glowProps.radiusY = 210
      pRenderTarget->CreateRadialGradientBrush (glowProps, BYVAL NULL, pGlowStops, pGlowBrush)
      ' // 3 Gold outline (solid brush)
      DIM pGoldBrush AS ID2D1SolidColorBrush PTR
      pRenderTarget->CreateSolidColorBrush( _
         D2D1_ColorF(1.0, 0.85, 0.2, 1.0), _   ' gold color
         BYVAL NULL, pGoldBrush)
      ' // 4) Bézier heart geometry
      DIM pGeoHeart AS ID2D1PathGeometry PTR
      DIM pSink     AS ID2D1GeometrySink PTR
      pFactory->CreatePathGeometry(pGeoHeart)
      pGeoHeart->Open(pSink)
      DIM AS SINGLE topX,topY : topX = 175 : topY =  90
      DIM AS SINGLE lcX,lcY   : lcX  =  70 : lcY  =  40
      DIM AS SINGLE lmX,lmY   : lmX  =  60 : lmY  = 150
      DIM AS SINGLE rcX,rcY   : rcX  = 280 : rcY  =  40
      DIM AS SINGLE rmX,rmY   : rmX  = 290 : rmY  = 150
      DIM AS SINGLE bx,by     : bx   = 175 : by   = 240
      pSink->BeginFigure(D2D1_Point2F(topX, topY), D2D1_FIGURE_BEGIN_FILLED)
      DIM L AS D2D1_BEZIER_SEGMENT
      L.point1 = D2D1_Point2F(lcX, lcY)
      L.point2 = D2D1_Point2F(lmX, lmY)
      L.point3 = D2D1_Point2F(bx,  by)
      pSink->AddBezier(L)
      DIM R AS D2D1_BEZIER_SEGMENT
      R.point1 = D2D1_Point2F(rmX, rmY)
      R.point2 = D2D1_Point2F(rcX, rcY)
      R.point3 = D2D1_Point2F(topX, topY)
      pSink->AddBezier(R)
      pSink->EndFigure(D2D1_FIGURE_END_CLOSED)
      pSink->Close
      pSink->Release
      ' Metallic loop above the heart
      ' // Metallic fill brush (radial gradient)
      DIM pLoopBrush AS ID2D1RadialGradientBrush PTR
      DIM pLoopStops AS ID2D1GradientStopCollection PTR
      DIM loopStops(2) AS D2D1_GRADIENT_STOP
      loopStops(0).position = 0.0
      loopStops(0).color    = D2D1_ColorF(1.0, 0.95, 0.6, 1.0)   ' bright gold center
      loopStops(1).position = 0.5
      loopStops(1).color    = D2D1_ColorF(0.9, 0.7, 0.2, 1.0)    ' warm gold
      loopStops(2).position = 1.0
      loopStops(2).color    = D2D1_ColorF(0.4, 0.3, 0.1, 1.0)    ' darker gold edge
      pRenderTarget->CreateGradientStopCollection (loopStops(0), 3, D2D1_GAMMA_2_2, D2D1_EXTEND_MODE_CLAMP, pLoopStops)
      DIM loopProps AS D2D1_RADIAL_GRADIENT_BRUSH_PROPERTIES
      loopProps.center = D2D1_Point2F(175, 60)         ' center of the loop
      loopProps.gradientOriginOffset = D2D1_Point2F(-10, -10)
      loopProps.radiusX = 40
      loopProps.radiusY = 40
      pRenderTarget->CreateRadialGradientBrush (loopProps, BYVAL NULL, pLoopStops, pLoopBrush )
      ' // Loop geometry (rounded arc)
      DIM pGeoLoop AS ID2D1PathGeometry PTR
      DIM pSink2   AS ID2D1GeometrySink PTR
      pFactory->CreatePathGeometry(pGeoLoop)
      pGeoLoop->Open(pSink2)
      ' Loop coordinates (small arc above the heart)
      DIM AS SINGLE lx1, ly1 : lx1 = 145 : ly1 =  80   ' left base
      DIM AS SINGLE lx2, ly2 : lx2 = 205 : ly2 =  80   ' right base
      DIM AS SINGLE cx,  cy  : cx  = 175 : cy  =  40   ' top of arc
      pSink2->BeginFigure(D2D1_Point2F(lx1, ly1), D2D1_FIGURE_BEGIN_FILLED)
      DIM arcseg AS D2D1_BEZIER_SEGMENT
      arcseg.point1 = D2D1_Point2F(150, 30)   ' left control
      arcseg.point2 = D2D1_Point2F(200, 30)   ' right control
      arcseg.point3 = D2D1_Point2F(lx2, ly2)  ' right base
      pSink2->AddBezier(arcseg)
      ' Close the bottom of the loop
      pSink2->AddLine(D2D1_Point2F(lx1, ly1))
      pSink2->EndFigure(D2D1_FIGURE_END_CLOSED)
      pSink2->Close
      pSink2->Release
      ' // Projected shadow for the èndant
      '  Create shadow brush (soft black)
      DIM pShadowBrush AS ID2D1SolidColorBrush PTR
          D2D1_ColorF(0.0, 0.0, 0.0, 0.35), _   ' translucent black
          BYVAL NULL, _
          pShadowBrush )
      '  Save current transform
      DIM oldTransform AS D2D1_MATRIX_3X2_F
      pRenderTarget->GetTransform(oldTransform)
      ' Build shadow transform
      DIM shadow AS D2D1_MATRIX_3X2_F
      ' Shadow pivot (same as pendant rotation pivot)
      DIM pivotX AS SINGLE : pivotX = 175
      DIM pivotY AS SINGLE : pivotY =  40
      ' Shadow tilt angle (stronger than pendant tilt)
      DIM angle AS SINGLE
      angle = -22.0   ' degrees
      ' // Build transform:
      ' 1) Move to pivot
      ' 2) Rotate
      ' 3) Squash vertically (fake blur)
      ' 4) Move downward
      shadow = _
          D2D1_MatrixTranslation(-pivotX, -pivotY) * _
          D2D1_MatrixRotation(angle, D2D1_Point2F(0, 0)) * _
          D2D1_MatrixScale(D2D1_SizeF(1.0, 0.35)) * _
          D2D1_MatrixTranslation(pivotX, pivotY + 160)
      ' Apply shadow transform
      pRenderTarget->SetTransform(shadow)
      ' // Draw shadow using the same geometries
      ' Heart shadow
      pRenderTarget->FillGeometry(pGeoHeart, pShadowBrush)
      ' Loop shadow
      pRenderTarget->FillGeometry(pGeoLoop, pShadowBrush)
      ' Chain shadow (ellipses)
      DIM AS SINGLE baseY      : baseY      = 35
      DIM AS SINGLE startX     : startX     = 115
      DIM AS SINGLE linkWidth  : linkWidth  = 22
      DIM AS SINGLE linkHeight : linkHeight = 10
      DIM AS SINGLE spacing    : spacing    = 18
      DIM AS INTEGER i
      DIM link AS D2D1_ELLIPSE
      FOR i = 0 TO 6
          DIM cx AS SINGLE : cx = startX + i * spacing
          DIM cy AS SINGLE : cy = baseY + 3 * SIN((i - 3) * 3.14159 / 6.0)
          link.point.x = cx
          link.point.y = cy
          link.radiusX = linkWidth  / 2.0
          link.radiusY = linkHeight / 2.0
          pRenderTarget->FillEllipse(link, pShadowBrush)
      '  // Restore original transform
      pRenderTarget->SetTransform(oldTransform)
      ' // Release shadow brush
      IF pShadowBrush THEN pShadowBrush->Release
      ' ======= Draw everything else =======
      ' // Fill the heart
      pRenderTarget->FillGeometry(pGeoHeart, pFillBrush)
      ' // Glow border (soft halo)
      pRenderTarget->DrawGeometry(pGeoHeart, pGlowBrush, 14.0)
      ' // Gold outline (sharp edge)
      pRenderTarget->DrawGeometry(pGeoHeart, pGoldBrush, 3.0)
      pGeoHeart->Release
      ' // Draw loop (fill + gold outline)
      pRenderTarget->FillGeometry(pGeoLoop, pLoopBrush)
      pRenderTarget->DrawGeometry(pGeoLoop, pGoldBrush, 3.0)
      pGeoLoop->Release
      ' // Release the loop resources
      D2D1_SafeRelease(pLoopBrush)
      D2D1_SafeRelease(pLoopStops)
   D2D1_SafeRelease(pFillBrush)
   D2D1_SafeRelease(pFillStops)
   D2D1_SafeRelease(pGoldBrush)
   D2D1_SafeRelease(pGlowBrush)
   D2D1_SafeRelease(pGlowStops)
   FUNCTION = hr
' Main
   CoInitialize NULL
   DIM hWin AS HWND = pWindow.Create(NULL, "D2D1 - Radial gradient brush", @WndProc)
   pWindow.SetClientSize(350, 300)
   pWindow.Center
   'pGraphCtx.Stretchable = TRUE
   CoUninitialize
   SELECT CASE uMsg
      CASE WM_CREATE
         RETURN 0
         RETURN 0
      CASE WM_COMMAND
            CASE IDCANCEL
         RETURN 0
      CASE WM_DESTROY
         PostQuitMessage(0)
         RETURN 0
Johan Klassen
good day José  :)
that example looks great
I recommended your work to Patrice Terrier who asked if webview2 worked with FB x64 https://www.freebasic.net/forum/viewtopic.php?p=311135
Yes, I have seen that post. Thanks very much.
Regarding Direct2D, I'm currently writing small didactic templates. I already have 66.
They're useful for me to learn how to use this technology and to test if my headers are correct. Now I'll try Direct Write and then WIC. This technology is a whole ecosystem.
#27
The old WebBrowser control used to navigate to HTTPS sites, although modern pages rendered incorrectly due to the outdated MSHTML engine. Older HTML pages still displayed fine.
After recent Windows updates, HTTPS support has effectively been removed from the legacy Internet Explorer engine, so the WebBrowser control can no longer load secure sites.
It still works with HTTP pages and local HTML files.
This change is permanent and expected, as Microsoft has fully deprecated Internet Explorer. Anyone still relying on the old WebBrowser control should migrate to WebView2 as soon as possible.
Fortunately, AfxNova provides classes for WebView2, which is the new standard and fully supports modern web technologies.
hajubu
#28
Hi, I just update my previous Html-Help for Tiko 1.3 , which is based on your md-DOCS-folder.
enclosed are two zip containing the changes , the instructions, and Readme
                    and the ready-to-use AfxNova_Web.
Readme_first_if_you_like.
Have Fun !
b.r. Hans (Hajubu)
# AfxNova_Web_2026
Readme for  updating  CWebview2.bas to AfxNova_webview2_2026
+ Hi, just updated the  'AfxNova-WebView2' , to integrate a Help Tool for the Docs for 'AfxNova' as html.
+ taken from examples latest in AfxNova-Main\AfxNova\WebView2\ dated ..._260528_1945 sha 998d7f1 ...
-  Changes
  - CWebview2.inc (UserDatafolder, now possible in "User-temp\..."
        - i.e. %userappdata%\\local\\temp\\...) or in ...
1. Markdown to html is done with pandoc - ( fence code rules needing an editor w. R E)
  * i.e. 1rst:  regex (```\r\n---\r\n)# -> (```\r\n\r\n---\r\n\r\n)#
  *      2nd:  regex (---\r\n)#        -> (---\r\n\r\n)#
  * and adapting  "Docs" folder names  i.e. Webview2 : - docs\WebWiev2 -> docs\Webview2
  * { A copy of AfxNova-Main-Readme is also available in html-folder }
  * Even when .md-docs are updated, the maintenance is an easy-peasy task (took me only 15 minutes)
  * The converted .Md-to-.html can just exchanged inside the folder structure.
2. When using 'pandoc' as a batch job - actual 137 - by keeping the folder structure the same as Jose's doc-folder
- it may be used any Browser locally
* OR on a Webserver (if you like)
* OR also within  IKO 1.3  TOOLS
* ... without or with an adapted Jose's CW_Webview2.bas
* Fitting dir_name_idx.html as page index in this structure let me use it as an offline Help
* Integrating in Tiko is no rocket science.  * It works a simple tool , but it helps a lot.
* File structure : html,css only ( no java,.js no php * no need !)
3. Optional
- Compiling sample  of AfxNova_WebView2_2026.bas sample
  - Creating/adapting some lines of code in the AfxNovaWeb.ini-file
  - Adapting some lines of the org. CW_Webviev2.bas for updated AfxNova_webview2.bas  ,
        - changing the pWebView2.Navigate(weburl) + start-index could be called from the app.
  - i.e. Instruction are in the CW_Snippet{1,2,3}_WebView2.txt for the CW_WebView2_2026.bas.
4. Epilog:
Archive:
    * The '_TestPan_AfxNovaWeb2_2026.zip' archive contains
      -  AfxNova_webview2_2026.bas
    * The zipped Readme
          {org_CW_WebView2.bas + snippets.txt(3)) + AfxNovaWeb.ini + this Readme.}
      -  and the AfxNova_Web as html structured folder
Info:
    * As the comiled Webview2-app is to large for upload ,
      attached is only the sources (*.bas,*.ini) in a zip.
    The names of the ini-file :AfxNovaWeb.ini is hardcoded in the source.
    * Please do not forget to adapt it to your needs at least in the ini-file.
    *  here the template for the ini-file :
    [AfxNovaWeb]
    Root="V:\_testpan\_AfxNovaWeb14\AfxNova_idx.html"
    Puri="file:///"
    *  Comiling with Tiko and AfxNova of _260528_1945 sha 998d7f1... needs
    * proj.folder : (work.tiko) new project: manifest.xml,resource.rc
    .\AfxNova_WebView2_2026.bas (sample)
    .\loader.js
    .\WebView2Loader.dll
    .\AfxNovaWeb.ini
    and UserDatafolder (applicable, if default is not %TEMP%)
    * and if testing at least:
    .\AfxNova_WebView2_2026.exe + .\AfxNovaWeb.ini + Userdatafolder/Temp
Have Fun !
Thanks very much for your efforts.
I've been experimenting with WebView2, and I'm genuinely impressed. This control gives desktop applications access to the full power of a modern browser, which means we can now integrate high‑quality images, animations, graphics, audio, video, printing, and much more—directly inside a native Windows program.
What makes this especially exciting is that the integration with FreeBasic is now seamless. The heavy lifting—initialization, DPI handling, resizing, message routing, and all the low‑level details—has already been solved. From this point on, everything becomes simple experimentation: write some HTML, add a bit of CSS, drop in a JavaScript library, and watch it come alive inside your application.
WebView2 also includes a fully localized context menu with built‑in features like copy, save, zoom, rotate, and print, all without writing any additional code. And because it uses the Chromium engine, we automatically get perfect DPI scaling, smooth zooming, crisp rendering, and support for the latest web standards.
There is an enormous ecosystem of JavaScript libraries available—charts, maps, UI frameworks, image processors, PDF generators, animation engines—and every one of them becomes instantly usable from FreeBasic through WebView2. With the help of AI, generating HTML, CSS, and JavaScript becomes even easier, making it possible to prototype and integrate advanced features in minutes.
In short, WebView2 gives us superpowers.
And now that it's fully integrated into FreeBasic, the only limit is our imagination. I'll be sharing examples so everyone can explore what this control can do. I'm just beginning to learn HTML, CSS, and JavaScript myself, but even at this early stage, the possibilities already look incredible.
