Getting error about system debugger
Started by Anonymous, December 17, 2005, 02:15:23 PM
Hmmm, I didn't think hooks would be it either...especially since the hook Paul mentions really isn't much and doesn't do hardly anything if at all with tooltips.  Perhaps a search about the message and tooltips or the TTM_... messages they send requesting info.  Winspector reports it is sending TTN_GETDISPINFO and TTN_SHOW, along with LVM_GETITEMW and WM_USER+3245. When the tooltip fires.  The listview in a common dialog also appears to be custom drawn.
Mark Strickland
If you cannot find the issue you might consider getting a new hard drive then use Ghost or some other tool to make an image back up.  Then switch out your primary drive with this "clone" and then reinstall Windows back on top of itself.  Normally it will keep all of the settings for installed apps.
If you like the thrill of taking risks you can do it without the backup on your main drive but it may become "way too thrilling" if you break Windows for good.
FireFly is clearly one of the best development tools on the planet.  Yep -- it has a few quirks and is not as mature as VB or other products but in combination with PowerBASIC it helps you write code the way it should be done.  I have an app built with FF that is nearly 300,000 lines of code.  With a little work I could probably get the EXE on one floppy.  Try that with VB.
FireFly is likely NOT the root cause of your problem but did manage to make it surface.
Good luck.
Anonymous
LOL -- Sounds like some people have time on their hands.
This system was installed less than three months ago and has only a bare minimum of software installed. Just what it takes to do its job. If FF can't work properly in that environment, then there's really nothing to remove and/or do without.
Although FF itself is probably not the root of the problem, it is fairly clear that Armadillo is. And were it not for FF Armadillo would not be on my system. For that matter, even if it is not Armadillo, I have no issues anywhere else except with FF. So as far as I'm concerned, this is a FF issue. Plus, this error is not all that uncommon in the general population, just uncommon for FF. It is not like I've stumbled on something that has never been seen before elsewhere.
No need to sell me on FF/PB either. I threw VB out eons ago. In fact, if it weren't for PB I wouldn't code for Windows at all. Even with PB, I find the Windows platform so horrendous that I do relatively little Windows coding anymore anyway. My bread and butter is in Linux (too bad PB has never delivered on the oft hinted PB/Linux!) Mainly I want to see how FF stacks up against the latest PB Forms and EZGUI. Any way you slice it, without a GUI builder -- whether PB/Forms or EZGUI or FF -- I would further limit my Windows programming to PB/CC.
Hopefully this is something Paul can sort out. From what I saw before I removed it, FF is a terrific product. I've used Jellyfish and Cheetah for several years, so a top notch product from Paul is not a surprise. However, copy protection schemes IMHO are just problems waiting to happen, and I almost never rely on software that has a copy protection scheme. FF might be the exception -- it did look really good -- but not if the copy protection scheme doesn't work on my system.
This is the response that I just received from Silicon Realms support. It doesn't really provide any new information unfortunately. :(
We don't recall any problems specific to hooked dialogs. One thing you mention is that this is only happening to one person... if that's the case, I would assume that this is a difference between their system and everyone else's, almost certainly related to some kind of software that that user is running (maybe something that tries to "improve" the dialog in question).
I hope that helps!
Regards,
Denis
As has already been pointed out, you don't have anything special installed on your system so we're still in the dark.
You use Linux and Windows... any chance that maybe you're running VMWare or similar type of software? Just taking a stab in the dark.
Anonymous
Nope, not on this system. I do have one system with vmware, but it is a linux system. I don't even have a Windows vm running on that one.
Not aware of any dialog enhancing tools either. I generally run a straight Windows load, and then add only the essential apps and utilities. Tends to work better that way. Usually :-)
I did a text search for a subset of the message text. Came up empty, so it is probably either encrypted or in a compressed file. Was hoping to at least tag the culprit file.
Maybe you could drop some trace info into the New Project file dialog and send it? Crumb up the screen all you want, whatever it would take to identify what/where exactly it comes from.
Did they by any chance mention if they had any ability to identify exactly what/which debugger they think they've found? The only ones I'm aware of would be the debug modes for IE and .NET -- both of which are disabled. And if those were the problem, then more folks than just me would be affected.
Your call. If you want to chase it down, I can load and run a hacked version with traces for you. Like I said, FF looks great, and I know your other work so I'm sure it is great. Don't mind spending some time to help you find this -- might help someone else down the road. You've got my email, so we can take this out of forum if you'd like, at least until we suss out something.
Best thing I see at this point since I imagine Paul doesn't want unprotected code out there is perhaps a app created with the protection that has various common dialogs, etc as FF has them and various other test cases to expose what this is doing.  Other things are checking the Event Logs in the Admin tools on the machine giving the errors for possible reports and/or other errors that may only be noted there and could shed light on the problem.  Other possibilities are what is loaded when the error occurs-  Services running (Admin Tools again), Event Logs also contain messages stating what services and such load too, Registry Run apps- both in Local Machine and Current User, and Start Menu Startup folder apps...plus any others loaded manually or by other means.
I know this may sound like a lot, but if I were having an error no one else experienced I'd want to figure out why...no telling what it could be and better safe than sorry if it is something on your machine that you don't want.  Sounds like you are worried about FF causing things too- "And were it not for FF Armadillo would not be on my system".  Armadillo isn't "on" your system, it is just in the exe file.  All it amounts to is code inside the exe to decompress the file and protect against debuggers running with standard win32 API...so if that causes problems then something is on your machine to compromise the protection...this may or may not have been put on the machine by you.  I too am one to always be on guard with things on my machine and monitor everything, including FF.  I even have a resource viewer that can view compressed exe's and nothing is in there but the basic icons, etc.
Also, if you have seen the other thread...it appears a user is having problems with hooks and such with themes turned on...maybe try it with both themes on and off to see if results differ.
Mark Strickland
I too would want to know why my system is different than all of the others that use FF.  One thing I have learned, especially with a security focus, is there are lots of hidden and ugly things that can and do go on inside of Windows.  Some accidental, some bugs, and some put there on purpose by some malware or accidentially by an errant program.
You like UNIX --- so do I --- for starters no registry.  If you want to un-install generally just RM the directory.  Graphics are not "wormed down deep inside" the Kernal that was required to get the performance in the "old days".  The list goes on but sadly Windows "owns" the desktop so we all have to live with it.
My suggestion for reloading Windows on a Ghosted disk was to try and eliminate any "funny" stuff.  If it works you will never know why but you can "move on".
This sounds like root kit stuff to me if you have not loaded any known but different software.  You can't see any difference from the outside because the problem is deep down inside of Windows.
Did you load a Sony CD recently?   ;-)
Just one opinion.
Anonymous
Nope, no recent loads since the original install (of the system, from bare metal) in October. And definitely nothing from Sony -- I don't think I even own anything by Sony ;-)
As to Armadillo being on my system or not, well, it is there in some form. Just because it's not loaded as a separate package, it is still "on there". It is part of Armadillo, Paul didn't write it, I gather its inner workings are black box in nature -- so it is kinda on there.
As to walking backwards through startup folder apps, registry loads, etc -- when you use msconfig to put the system in diagnostic mode, it strips out almost everything that is not Windows essential. The running tasks list gets very short in this mode. Since the problem was still in evidence in diag mode, with nothing much running, it would be pointless to piecemeal through the stuff manually. It is apparent the interaction is in some fairly low level, core stuff, probably some updated DLL. The next step, if you really wanted to dig through it, would be to check the DLL versions of what is running in diag mode and see what is different from a "clean" load, and start swapping at that level. That's a pain!
I'm not suggesting Paul put out unprotected code. (Okay, so I sorta am -- copy protection sucks and isn't all that effective imho -- but it does give the 'bad' hackers a purpose in life I suppose.) That aside, what I WAS suggesting was that Paul simply put in some debug-like traces in the file dialog to help identify exactly what triggers the error dialog. That is definitely not unprotected code -- that would be annoying as hell code! :) But it might narrow the search.
Patiently waiting for Paul to weigh in. This is definitely not something to interrupt the holidays over :-) It won't upset my apple cart if this takes a good while to sort out. Heck, I'm still waiting for an email confirmation from PB of the updates I ordered on Sunday...
I will create a small application that uses FireFly's "Open' dialog (the one with the hooked dialog). I will then post it in both protected and unprotected exe's. Hopefully I can get that done today. Lots on my plate today but I will give it a shot.
Okay, I uploaded a simple zip file that contains two EXE's. One is protected with Armadillo and the other is not. Try both to see what happens. The code is the sample PBNote source with the FireFly new open dialog added to it.
http://www.planetsquires.com/files/newopentest.zip
Anonymous
Okay, downloaded and tried both apps. The unprotected one works just fine. The file tip pops up as expected. The protected one yields the same alert dialog (btw, that means both the message and the alert sound) and never does pop up the file tip -- which is the same as I see in FF.
I think that means we can conclude it is an Armadillo interaction. The question is: Interaction with what? Is there nothing Armadillo provides that would allow a developer to identify the conflicting debugger?
Thanks for testing the code and confirming that there is still a problem.
Quote from: grimblefritzIs there nothing Armadillo provides that would allow a developer to identify the conflicting debugger?
I will send a message to support to see if they can help (maybe they can produce a debug version that will display the debugger name).
Here is part of the message that I just sent to Armadillo support:
So, my question to you, can you protect the "unprotected" sample EXE
in the above download with a debug version of Armadillo that will
display the name of the suspected debugger???? We want to try to track
down what is the offending piece of software on the user's system. He
swears that his system is just a plain, vanilla, WinXP Professional
installation (with SP2).
Hmm, this is just plain odd.  One other thing to track down is if it is the common dialog or the tooltip.  Do any other tooltips work in FF like the icons/buttons in the tool panel where you add the controls?  Maybe a tester app with a window containing tooltips and one with some kind of keyboard hook or something and tooltips.  Might try different code too like the code I posted for balloon tips with both cases too to see if there is a difference in standard and balloon tips, etc.  To me it is odd why, if there is an app/virus/infection, it would be monitoring common dialogs/tooltips.  Lots of data could be "harvested" that way...but what/why they are doing it or what it is after would be a mystery worth solving.
IsDebuggerPresent is probably at least one of the APIs they are using, but it appears to be only boolean.  DebugBreak, FatalExit, or OutputDebugString may help in figuring out what is loading on the system.  If it is loaded with FF chances are it is loaded with all apps and you could write one to return if one is present then try breaking/exiting to it or writing a string that may be output somewhere and lead you to where it is.
