Proposed changes and additions for version 1.04 of my headers
Started by José Roca, May 10, 2012, 03:51:20 PM
My translation of the SQLite headers will be incorporated to my headers package, since I have writen some classes that use them. The classes allow to use SQLite with structured exception handling and get rich error information.
A little example:
' Microsoft Windows
' File: CSQLITE_Step.bas
' Contents: CSQLite class example
' Connects to a database and reads records.
' Copyright (c) 2012 Jose Roca. Freeware. Use at your own risk.
' Portions Copyright (c) Microsoft Corporation. All Rights Reserved.
#COMPILE EXE
#DIM ALL
#INCLUDE ONCE "CSQLite.INC"
' Main
FUNCTION PBMAIN
   LOCAL pSQL AS ISQLite
   pSQL = CLASS "CSQLite"
   IF ISNOTHING(pSQL) THEN EXIT FUNCTION
   ' // Create a connection object
   LOCAL pDbc AS ISQLiteConnection
   pDbc = pSQL.Connection
   IF ISNOTHING(pDbc) THEN EXIT FUNCTION
   TRY
      ' // Delete our test database if it exists
      IF ISFILE(EXE.PATH$ & "Test.sdb") THEN KILL EXE.PATH$ & "Test.sdb"
      ' // Create a new database
      pDbc.OpenDatabase(EXE.PATH$ & "Test.sdb")
      ' // Create a table
      pDbc.Exec("CREATE TABLE t (xyz text)")
      ' // Insert rows
      pDbc.Exec("INSERT INTO t (xyz) VALUES ('fruit')")
      pDbc.Exec("INSERT INTO t (xyz) VALUES ('fish')")
'      ' // Prepare a query
      LOCAL pStmt AS ISQLiteStatement
      pStmt = pDbc.Prepare("SELECT * FROM t")
      ? "Column count:" & STR$(pStmt.ColumnCount)
      ' // Read the column names and values
      LOCAL i AS LONG
      DO
         ' // Fetch rows of the result set
         IF pStmt.Step = %SQLITE_DONE THEN EXIT DO
         ' // Read the columns and values
         FOR i = 0 TO pStmt.ColumnCount- 1
            ? pStmt.ColumnName(i)
            ? pStmt.ColumnText(i)
      LOOP
   CATCH
     ' // Display error information
      ? pSql.OleErrorInfo
   END TRY
   ' // Cleanup
   pDbc = NOTHING   ' // Closes the database
   pSQL = NOTHING
   #IF %DEF(%PB_CC32)
      WAITKEY$
   #ENDIF
File AfxWin.inc
' Retrieves the path of the executable file given its instance handle.
FUNCTION AfxGetPathFromhInstance (BYVAL hInst AS DWORD) AS WSTRING
   LOCAL hProcess AS DWORD, wszPath AS WSTRINGZ * %MAX_PATH
   IF hInst = 0 THEN EXIT FUNCTION
   hProcess = OpenProcess(%PROCESS_QUERY_INFORMATION OR %PROCESS_VM_READ, %FALSE, hInst)
   IF hProcess = 0 THEN EXIT FUNCTION
   GetModuleFileNameExW(hProcess, %NULL, wszPath, SIZEOF(wszPath))
   CloseHandle(hProcess)
   FUNCTION = wszPath
File AfxWin.inc
' Retrieves the path of the executable file that created the specified window.
FUNCTION AfxGetPathFromWindowHandle (BYVAL hwnd AS DWORD) AS WSTRING
   LOCAL idProc, hProcess AS DWORD, wszPath AS WSTRINGZ * %MAX_PATH
   GetWindowThreadProcessId(hwnd, idProc)
   IF idProc = 0 THEN EXIT FUNCTION
   hProcess = OpenProcess(%PROCESS_QUERY_INFORMATION OR %PROCESS_VM_READ, %FALSE, idProc)
   FUNCTION = wszPath
