Proposed changes and additions for version 1.04 of my headers
Started by José Roca, May 10, 2012, 03:51:20 PM
- File CAfxProtableDevices changed to CAfxPortableDevices. It was a typo.
- CWindow_InputBox function (CWindow.inc file)
Added the optional parameter bPassword. If TRUE, the text will be replaced with the default password character.
#1
File: AfxWin.inc
' Gets the token elevation type for the current process.
' Token elevation values describe the relative strength of a given token.
' A full token is a token with all groups and privileges to which the principal
' is authorized.  A limited token is one with some groups or privileges removed.
' Requires Windows Vista or superior.
FUNCTION AfxGetTokenElevationType () AS LONG
   LOCAL hToken AS DWORD
   LOCAL elevationType AS LONG
   LOCAL dwSize AS DWORD
   IF OpenProcessToken(GetCurrentProcess, %TOKEN_QUERY, hToken) = 0 THEN EXIT FUNCTION
#IF %DEF(%USEPBDECL)
   GetTokenInformation(hToken, %TokenElevationType, BYVAL VARPTR(elevationType), 4, dwSize)
#ELSE
   GetTokenInformation(hToken, %TokenElevationType, elevationType, 4, dwSize)
#ENDIF
   CloseHandle(hToken)
   FUNCTION = elevationType
#2
File: AfxWin.inc
' Converts point size to DIP (device independent pixel). DIP is defined as 1/96 of an
' inch and a point is 1/72 of an inch.
FUNCTION AfxPointSizeTopDip (BYVAL ptsize AS SINGLE) AS SINGLE
   FUNCTION = (ptsize/72) * 96
File: AfxSid.inc
' Tests whether the current user is a member of the Administrator's group.
' Caller is NOT expected to be impersonating anyone and is expected to be able to
' open its own process and process token.
' See: http://msdn.microsoft.com/en-us/library/windows/desktop/aa376389%28v=vs.85%29.aspx
' Return Value:
'   TRUE - Caller has Administrators local group.
'   FALSE - Caller does not have Administrators local group.
' Note: Replacement for the Windows API function IsUserAnAdmin because Microsoft warns
' about the use of this function and advices to call CheckTokenMembership directly.
FUNCTION AfxIsUserAnAdmin () AS LONG
   LOCAL IsMember AS LONG
   LOCAL NtAuthority AS SID_IDENTIFIER_AUTHORITY
   LOCAL AdministratorsGroup AS DWORD
   NtAuthority.Value = $SECURITY_NT_AUTHORITY
   IF AllocateAndInitializeSid(NtAuthority, 2, %SECURITY_BUILTIN_DOMAIN_RID, _
         %DOMAIN_ALIAS_RID_ADMINS, 0, 0, 0, 0, 0, 0, AdministratorsGroup) = 0 THEN EXIT FUNCTION
   IF CheckTokenMembership(%NULL, BYVAL AdministratorsGroup, IsMember) <> 0 THEN
      FUNCTION = IsMember
   FreeSid(BYVAL AdministratorsGroup)
File: AfxSid.inc
' Looks up the user name and domain name for the user account associated with the specified
' local process identifier.
FUNCTION AfxGetUserNameAndDomainFromPid (BYVAL pid AS DWORD, BYREF bstrUser AS WSTRING, BYREF bstrDomain AS WSTRING) AS LONG
   LOCAL hProcess AS DWORD
   LOCAL ptiUser AS TOKEN_USER PTR
   LOCAL cbti AS DWORD
   LOCAL snu AS LONG  ' SID_NAME_USE enumeration
   LOCAL wszUser AS WSTRINGZ * 256
   LOCAL wszDomain AS WSTRINGZ * %MAX_PATH
   ' // Open the local process
   hProcess = OpenProcess(%PROCESS_ALL_ACCESS, %FALSE, pid)
   IF hProcess = %NULL THEN
      FUNCTION = GetLastError
   ' // Get the access token associated with the process
   IF ISFALSE OpenProcessToken(hProcess, %TOKEN_QUERY, hToken) THEN
      GOTO LExit
   ' // Obtain the size of the user information in the token
   IF GetTokenInformation(hToken, %TokenUser, BYVAL %NULL, 0, cbti) <> 0 THEN
      GOTO LExit
   ' // Call should have failed due to zero-length buffer
   IF GetLastError <> %ERROR_INSUFFICIENT_BUFFER THEN
      GOTO LExit
   ' // Allocate buffer for user information in the token
   ptiUser = HeapAlloc(GetProcessHeap, %HEAP_GENERATE_EXCEPTIONS, cbti)
   IF ptiUser = %NULL THEN
      FUNCTION = %E_OUTOFMEMORY
      GOTO LExit
   ' // Retrieve the user information from the token
   IF ISFALSE GetTokenInformation(hToken, %TokenUser, BYVAL ptiUser, cbti, cbti) THEN
      GOTO LExit
   ' // Retrieve user name and domain name based on user's SID.
   IF ISFALSE LookupAccountSidW(BYVAL %NULL, BYVAL @ptiUser.User.Sid, wszUser, SIZEOF(wszUser), _
              wszDomain, SIZEOF(wszDomain), snu) <> 0 THEN
      GOTO LExit
   bstrUser = wszUser
   bstrDomain = wszDomain
LExit:
   ' // Free resources
   IF hProcess THEN CloseHandle(hProcess)
   IF hToken THEN CloseHandle(hToken)
   IF ptiUser THEN HeapFree(GetProcessHeap, 0, ptiUser)
#5
File: CAfxMp3.inc. Plays MP3 files.
' Microsoft Windows
' File: CAfxMp3.inc
' Contents: MP3 class.
' Copyright (c) 2012 Jose Roca.
' Based on Simple C++ DirectShow MP3 Player Class by Wong Shao Voon, 26 Apr 2010.
' http://www.codeproject.com/Articles/373613/Simple-Cplusplus-DirectShow-MP3-Player-Class
#INCLUDE THIS ONCE
%CAFXMP3_INC = 1
#INCLUDE ONCE "windows.inc"
#INCLUDE ONCE "DShow.inc"     ' // Director Show
' CAfxMp3 class.
CLASS CAfxMp3
   INSTANCE m_pIGraphBuilder AS IGraphBuilder
   INSTANCE m_pIMediaControl AS IMediaControl
   INSTANCE m_pIMediaEventEx AS IMediaEventEx
   INSTANCE m_pIBasicAudio AS IBasicAudio
   INSTANCE m_pIMediaSeeking AS IMediaSeeking
   INSTANCE m_ready AS LONG
   INSTANCE m_duration AS QUAD
   INTERFACE IAfxMp3 : INHERIT IAutomation
   ' Cleans resources
   METHOD Cleanup
      m_pIGraphBuilder = NOTHING
      m_pIMediaControl = NOTHING
      m_pIMediaEventEx = NOTHING
      m_pIBasicAudio = NOTHING
      m_pIMediaSeeking = NOTHING
   END METHOD
   ' Builds a filter graph that renders the specified file.
   ' Return Value = %TRUE or %FALSE.
   ' OBJRESULT
   '   %S_OK = Success.
   '   %VFW_S_AUDIO_NOT_RENDERED = Partial success; the audio was not rendered.
   '   %VFW_S_DUPLICATE_NAME = Success; the Filter Graph Manager modified the filter name to avoid duplication.
   '   %VFW_S_PARTIAL_RENDER = Some of the streams in this movie are in an unsupported format.
   '   %VFW_S_VIDEO_NOT_RENDERED = Partial success; some of the streams in this movie are in an unsupported format.
   '   %E_ABORT = Operation aborted.
   '   %E_FAIL = Failure.
   '   %E_INVALIDARG = Argument is invalid.
   '   %E_OUTOFMEMORY = Insufficient memory.
   '   %E_POINTER = NULL pointer argument.
   '   %VFW_E_CANNOT_CONNECT = No combination of intermediate filters could be found to make the connection.
   '   %VFW_E_CANNOT_LOAD_SOURCE_FILTER = The source filter for this file could not be loaded.
   '   %VFW_E_CANNOT_RENDER = No combination of filters could be found to render the stream.
   '   %VFW_E_INVALID_FILE_FORMAT = The file format is invalid.
   '   %VFW_E_NOT_FOUND = An object or name was not found.
   '   %VFW_E_UNKNOWN_FILE_TYPE = The media type of this file is not recognized.
   '   5VFW_E_UNSUPPORTED_STREAM = Cannot play back the file: the format is not supported.
   METHOD Load (BYVAL bstrFile AS WSTRING) AS LONG
      LOCAL hr AS LONG
      m_ready = %FALSE
      ME.Cleanup
      m_pIGraphBuilder = NEWCOM CLSID $CLSID_FilterGraph
      IF ISNOTHING(m_pIGraphBuilder) THEN EXIT METHOD
      m_pIMediaControl = m_pIGraphBuilder
      m_pIMediaEventEx = m_pIGraphBuilder
      m_pIBasicAudio = m_pIGraphBuilder
      m_pIMediaSeeking = m_pIGraphBuilder
      hr = m_pIGraphBuilder.RenderFile(BYCOPY bstrFile)
      IF SUCCEEDED(hr) THEN
         m_ready = %TRUE
         IF ISOBJECT(m_pIMediaSeeking) THEN
            m_pIMediaSeeking.SetTimeFormat($TIME_FORMAT_MEDIA_TIME)   ' // Reference time (100-nanosecond units).
            m_pIMediaSeeking.GetDuration(m_duration)                  ' // Returns 10,000,000 for a second.
      METHOD = m_ready
      IF hr THEN METHOD OBJRESULT = hr
   END METHOD
   ' Runs all the filters in the filter graph.
   ' OBJRESULT
   '   %S_FALSE The graph is preparing to run, but some filters have not completed the transition to a running state.
   '   %S_OK = All filters in the graph completed the transition to a running state.
   METHOD Run () AS LONG
      IF ISTRUE(m_ready) AND ISOBJECT(m_pIMediaControl) THEN
         m_pIMediaControl.Run
         IF ISFALSE OBJRESULT THEN METHOD = %TRUE ELSE METHOD OBJRESULT = OBJRESULT
   END METHOD
   ' Pauses all the filters in the filter graph.
   ' OBJRESULT
   '   %S_FALSE The graph paused successfully, but some filters have not completed the state transition.
   '   %S_OK = All filters in the graph completed the transition to a paused state.
   METHOD Pause () AS LONG
      LOCAL hr AS LONG
         m_pIMediaControl.Pause
   END METHOD
   ' Stops all the filters in the filter graph.
   ' OBJRESUT = Returns S_OK if successful, or an HRESULT value that indicates the cause of the error.
   METHOD Stop () AS LONG
      LOCAL hr AS LONG
         m_pIMediaControl.Stop
   END METHOD
   ' Waits for the filter graph to render all available data.
   ' Parameters:
   ' msTimeout
   '   [in] Duration of the time-out, in milliseconds. Pass zero to return immediately.
   '   To block indefinitely, pass INFINITE.
   ' EvCode
   '   [out] Event that terminated the wait. This value can be one of the following:
   '   %EC_COMPLETE  = Operation completed.
   '   %EC_ERRORABORT = Error. Playback cannot continue.
   '   %EC_USERABORT  = User terminated the operation.
   '   Zero (0) = Operation has not completed.
   ' OBJRESULT
   '   %S_OK = Success.
   '   %E_ABORT = Time-out expired.
   '   %VFW_E_WRONG_STATE = The filter graph is not running.
   ' Remarks
   ' This method blocks until the time-out expires, or one of the following events occurs:
   '   %EC_COMPLETE
   '   %EC_ERRORABORT
   '   %EC_USERABORT
   ' During the wait, the method discards all other event notifications.
   ' If the return value is S_OK, the pEvCode parameter receives the event code that ended
   ' the wait. When the method returns, the filter graph is still running. The application
   ' can pause or stop the graph, as appropriate.
   METHOD WaitForCompletion (BYVAL msTimeout AS LONG, BYREF EvCode AS LONG) AS LONG
      LOCAL hr AS LONG
      IF ISTRUE(m_ready) AND ISOBJECT(m_pIMediaEventEx) THEN
         m_pIMediaEventEx.WaitForcompletion(msTimeout, EvCode)
   END METHOD
   ' Retrieves the volume (amplitude) of the audio signal.
   ' Return Value = The volume. Divide by 100 to get equivalent decibel value.
   '                For example, â€"10,000 is â€"100 dB.
   ' OBJRESULT
   '   %E_NOTIMPL = The filter graph does not contain an audio renderer filter.
   '                (Possibly the source does not contain an audio stream.)
   '   %S_OK = Success.
   PROPERTY GET Volume () AS LONG
      IF ISTRUE m_ready AND ISOBJECT(m_pIBasicAudio) THEN
         PROPERTY = m_pIBasicAudio.Volume
         IF ISFALSE OBJRESULT THEN PROPERTY = %TRUE ELSE PROPERTY OBJRESULT = OBJRESULT
   END PROPERTY
   ' Sets the volume (amplitude) of the audio signal.
   ' OBJRESULT
   '   %E_FAIL = The underlying audio device returned an error.
   '   %E_INVALIDARG = The value of lVolume is invalid.
   '   %S_OK = Success.
   PROPERTY SET Volume (BYVAL nVol AS LONG)
         m_pIBasicAudio.Volume = nVol
         IF OBJRESULT THEN PROPERTY OBJRESULT = OBJRESULT
   END PROPERTY
   ' Gets the duration of the stream, in 100-nanosecond units.
   ' Returns 10,000,000 for a second.
   PROPERTY GET Duration () AS QUAD
      PROPERTY = m_duration
   END PROPERTY
   ' Gets the current position, relative to the total duration of the stream.
   PROPERTY GET CurrentPosition () AS QUAD
      LOCAL hr AS LONG
      LOCAL curPos AS QUAD
      IF ISTRUE m_ready AND ISOBJECT(m_pIMediaSeeking) THEN
         m_pIMediaSeeking.GetCurrentPosition(curPos)
         IF SUCCEEDED(hr) THEN PROPERTY = curPos ELSE PROPERTY OBJRESULT = hr
   END PROPERTY
   ' Sets the current position and the stop position.
   ' Parameters:
   '   pCurrent = [in, out] Pointer to a variable that specifies the current position, in units of the current time format.
   '   pStop = [in, out] Pointer to a variable that specifies the stop time, in units of the current time format.
   '   bAbsolutePositioning = %TRUE or %FALSE. IF %TRUE, the specified position is absolute.
   '                          IF %FLASE, the specified position is relative.
   ' OBJRESULT
   '   %S_FALSE = No position change. (Both flags specify no seeking.)
   '   %S_OK = Success.
   '   %E_INVALIDARG = Invalid argument.
   '   %E_NOTIMPL = Method is not supported.
   METHOD SetPositions (BYREF pCurrent AS QUAD, BYREF pStop AS QUAD, BYVAL bAbsolutePositioning AS LONG) AS LONG
      LOCAL hr AS LONG
      LOCAL dwFlags AS DWORD
         IF bAbsolutePositioning THEN
            dwFlags = %AM_SEEKING_AbsolutePositioning OR %AM_SEEKING_SeekToKeyFrame
            dwFlags = %AM_SEEKING_RelativePositioning OR %AM_SEEKING_SeekToKeyFrame
         hr = m_pIMediaSeeking.SetPositions(pCurrent, dwFlags, pStop, dwFlags)
         IF SUCCEEDED(hr) THEN METHOD = %TRUE ELSE METHOD OBJRESULT = hr
   END METHOD
   END INTERFACE
END CLASS
Usage example:
#COMPILE EXE
#DIM ALL
#INCLUDE ONCE "CAfxMp3.inc"
FUNCTION PBMAIN () AS LONG
   LOCAL pAfxMp3 AS IAfxMp3
   pAfxMp3 = CLASS "CAfxMp3"
   IF ISNOTHING(pAfxMp3) THEN EXIT FUNCTION
   TRY
      ' // Load the MP3 file
      pAfxMp3.Load(EXE.PATH$ & "Kalimba.mp3")   ' --> change me
      ' // Play it
      pAfxMp3.Run
      ' // ... after some time, stop it
      WAITKEY$
      pAfxMp3.Stop
   CATCH
      ? HEX$(OBJRESULT)
      WAITKEY$
   END TRY
#6
File: GdipUtils.inc.
Displays the printer dialog and prints the specified image at its real size or stretched to the paper size. Allows printing of multiframe .tif files.
' Displays the printer dialog and prints the specified image.
' Parameters:
' - wszFileName = The name of the image file to print.
' - bStretch = %TRUE or FALSE. Stretch the image to paper size.
' - nStretchMode = Stretching mode. Deafault value = %InterpolationModeHighQualityBicubic.
'   %InterpolationModeLowQuality = 1
'   %InterpolationModeHighQuality = 2
'   %InterpolationModeBilinear = 3
'   %InterpolationModeBicubic = 4
'   %InterpolationModeNearestNeighbor = 5
'   %InterpolationModeHighQualityBilinear = 6
'   %InterpolationModeHighQualityBicubic = 7
' Return Value: Return %TRUE if the bitmap has been printed successfully, or %FALSE otherwise.
FUNCTION GdiPlusPrintImageDlg(BYREF wszFileName AS WSTRINGZ, OPTIONAL BYVAL bStretch AS LONG, BYVAL nStretchMode AS LONG) AS LONG
   ' // Display te print dialog
   LOCAL hr AS LONG
   LOCAL ppd AS PRINTDLGAPIW
   ppd.lStructSize = SIZEOF(PRINTDLGAPIW)
   ppd.flags = %PD_RETURNDC OR %PD_ALLPAGES OR %PD_NOPAGENUMS OR %PD_NOSELECTION
   hr = PrintDlgW(ppd)
   IF hr <> %PD_RESULT_PRINT THEN EXIT FUNCTION
   LOCAL token AS DWORD
   LOCAL StartupInput AS GdiplusStartupInput
   ' // Initialize GDI+
   StartupInput.GdiplusVersion = 1
   hr = GdiplusStartup(token, StartupInput, BYVAL %NULL)
   IF hr THEN GOTO LExit
   LOCAL hStatus AS LONG
   LOCAL pGraphics AS DWORD
   ' // Create a graphics object from the printer DC
   hStatus = GdipCreateFromHDC(ppd.hDc, pGraphics)
   IF hStatus <> %S_OK OR pGraphics = 0 THEN GOTO LExit
   ' // Create a Bitmap object from a JPEG file.
   LOCAL pBitmap AS DWORD
   hStatus = GdipCreateBitmapFromFile(wszFileName, pBitmap)
   IF hStatus <> %S_OK OR pBitmap = 0 THEN GOTO LExit
   ' // Get the width and height of the bitmap
   LOCAL nWidth, nHeight AS DWORD
   GdipGetImageWidth(pBitmap, nWidth)
   GdipGetImageHeight(pBitmap, nHeight)
   ' // Stretching
   LOCAL cx, cy AS SINGLE
   IF bStretch THEN
      IF nStretchMode THEN
         ' // Set the interpolation mode
         IF nStretchMode = 0 THEN nStretchMode = %InterpolationModeHighQualityBicubic
         GdipSetInterpolationMode(pGraphics, nStretchMode)
      ' // Get the DPIs of the printer
      LOCAL dpiX, dpiY AS SINGLE
      GdipGetDpiX(pGraphics, dpiX)
      GdipGetDpiY(pGraphics, dpiY)
      ' // Calculate the width and height according to the DPI of the printer
      cx = GetDeviceCaps(ppd.hDc, %HORZRES) / (dpiX / 100)
      cy = GetDeviceCaps(ppd.hDc, %VERTRES) / (dpiY / 100)
   ' // How many frame dimensions does the Image object have?
   LOCAL nCount AS LONG
   hStatus = GdipImageGetFrameDimensionsCount(pBitmap, nCount)
   IF nCount THEN
      DIM dimensionIDs(0) AS GUID
      LOCAL frameCount AS DWORD
      ' // Get the list of frame dimensions from the Image object.
      REDIM dimensionIDs(nCount - 1)
      hStatus = GdipImageGetFrameDimensionsList(pBitmap, dimensionIDs(0), nCount)
      ' // Display the GUID of the first (and only) frame dimension.
      ' // Get the number of frames in the first dimension.
      hStatus = GdipImageGetFrameCount(pBitmap, dimensionIDs(0), frameCount)
      IF frameCount = 0 THEN GOTO LExit
   ' // Frame dimension page
   LOCAL pageGuid AS GUID
   pageGuid = $FrameDimensionPage
   ' // Print the bitmap
   LOCAL di AS DOCINFOW
   di.cbSize = SIZEOF(DOCINFOW)
   di.lpszDocName = VARPTR(wszFileName)
   hr = StartDocW(ppd.hDc, di)
   IF hr <= 0 THEN GOTO LExit
   LOCAL i, x AS LONG
   FOR i = 1 TO ppd.nCopies
      FOR x = 0 TO frameCount - 1
         IF StartPage(ppd.hDc) THEN
            ' // Select the frame
            hStatus = GdipImageSelectActiveFrame(pBitmap, pageGuid, x)
            ' // Draw the image
            IF bStretch THEN
               hStatus = GdipDrawImageRect(pGraphics, pBitmap, 0, 0, cx, cy)
               hStatus = GdipDrawImage(pGraphics, pBitmap, 0, 0)
            EndPage(ppd.hDc)
   EndDoc(ppd.hDc)
LExit:
   ' // Cleanup
   IF ppd.hDc THEN DeleteDC ppd.hDc
   IF pBitmap THEN GdipDisposeImage(pBitmap)
   IF pGraphics THEN GdipDeleteGraphics(pGraphics)
   ' // Shutdown GDI+
   IF token THEN GdiplusShutdown token
File: GdipUtils.inc
This one prints the image directly to the default printer.
' Prints the specified image using the current default printer and printer settings.
' Parameters:
' - bStretch = %TRUE or %FALSE. Stretch the image to paper size.
' - nStretchMode = Stretching mode. Default value = %InterpolationModeHighQualityBicubic.
' Return Value: Returns %TRUE if the bitmap has been printed successfully, or %FALSE otherwise.
FUNCTION GdiPlusPrintImage (BYREF wszFileName AS WSTRINGZ, OPTIONAL BYVAL bStretch AS LONG, BYVAL nStretchMode AS LONG) AS LONG
   ' // Get the name of the default printer
   LOCAL wszPrinterName AS WSTRINGZ * %MAX_PATH
   GetProfileStringW("WINDOWS", "DEVICE", "", wszPrinterName, SIZEOF(wszPrinterName))
   wszPrinterName = PARSE$(wszPrinterName, 1)
   IF wszPrinterName = "" THEN EXIT FUNCTION
   ' // Open the printer
   LOCAL hPrinter AS DWORD
   IF OpenPrinterW(wszPrinterName, hPrinter, BYVAL %NULL) = 0 THEN EXIT FUNCTION
   ' // Allocate a buffer of the correct size
   LOCAL dwNeeded AS DWORD
   LOCAL bufferDoc AS STRING
   dwNeeded = DocumentPropertiesW(%NULL, hPrinter, wszPrinterName, BYVAL %NULL, BYVAL %NULL, 0)
   bufferDoc = SPACE$(dwNeeded)
   ' // Retrieve the printer configuration data
   LOCAL nRet AS LONG
   nRet = DocumentPropertiesW(%NULL, hPrinter, wszPrinterName, BYVAL STRPTR(bufferDoc), BYVAL %NULL, %DM_OUT_BUFFER)
   IF nRet <> %IDOK THEN GOTO LExit
   ' // Cast it to a DEVMODEW structure
   LOCAL pDevMode AS DEVMODEW PTR
   pDevMode = STRPTR(bufferDoc)
   ' // Create a device context for the printer
   LOCAL hdc AS DWORD
   hdc = CreateDCW(wszPrinterName, wszPrinterName, BYVAL %NULL, BYVAL pDevMode)
   IF hdc = %NULL THEN GOTO LExit
   LOCAL hr AS LONG
   hStatus = GdipCreateFromHDC(hdc, pGraphics)
   ' // Create a Bitmap object from a file.
   ' // Stretching
   IF bStretch THEN
      ' // Calculate the width and height according to the DPIs of the printer
      cx = GetDeviceCaps(hdc, %HORZRES) / (dpiX / 100)
      cy = GetDeviceCaps(hdc, %VERTRES) / (dpiY / 100)
   IF nCount THEN
      ' // Get the number of frames in the first (and only) frame dimension.
   hr = StartDocW(hdc, di)
   LOCAL i, x AS LONG
   FOR i = 1 TO @pDevMode.dmCopies
         IF StartPage(hdc) THEN
            ' // Draw the image
            IF bStretch THEN
            EndPage(hdc)
   EndDoc(hdc)
LExit:
   ' // Finished with the printer
   IF hPrinter THEN ClosePrinter(hPrinter)
   ' // Cleanup
   IF hdc THEN DeleteDC(hdc)
   ' // Shutdown GDI+
File: GdipUtils.inc
' Displays the printer dialog and prints the specified resource image.
' Parameters:
' - hInstance = The instance handle.
' - wszImageName = The name of the image to print.
FUNCTION GdiPlusPrintResourceImageDlg(BYVAL hInstance AS DWORD, BYREF wszImageName AS WSTRINGZ, OPTIONAL BYVAL bStretch AS LONG, BYVAL nStretchMode AS LONG) AS LONG
   IF hInstance = 0 THEN EXIT FUNCTION
   LOCAL hr AS LONG
   ppd.flags = %PD_RETURNDC OR %PD_ALLPAGES OR %PD_NOPAGENUMS OR %PD_NOSELECTION OR %PD_DISABLEPRINTTOFILE
   hr = PrintDlgW(ppd)
   ' // Create a bitmap from the resource image
   LOCAL hResource     AS DWORD                 ' // Resource handle
   LOCAL pResourceData AS DWORD                 ' // Pointer to the resoruce data
   LOCAL hGlobal       AS DWORD                 ' // Global memory handle
   LOCAL pGlobalBuffer AS DWORD                 ' // Pointer to global memory buffer
   LOCAL pImageStream  AS IStream               ' // IStream interface pointer
   LOCAL pBitmap       AS DWORD                 ' // Bitmap object
   LOCAL imageSize     AS DWORD                 ' // Image size
   LOCAL wID           AS WORD
   LOCAL dwID          AS DWORD
   ' // Find the resource and lock it
   IF LEFT$(wszImageName, 1) = "#" THEN
      wID = VAL(MID$(wszImageName, 2))
      dwID = MAK(DWORD, wID, 0)
      hResource = FindResourceW(hInstance, BYVAL dwID, BYVAL %RT_RCDATA)
      hResource = FindResourceW(hInstance, wszImageName, BYVAL %RT_RCDATA)
   IF hResource = %NULL THEN GOTO LExit
   imageSize = SizeofResource(hInstance, hResource)
   IF imageSize = 0 THEN GOTO LExit
   pResourceData = LockResource(LoadResource(hInstance, hResource))
   IF pResourceData = %NULL THEN GOTO LExit
   ' // Allocate memory to hold the image
   hGlobal = GlobalAlloc(%GMEM_MOVEABLE, imageSize)
   IF hGlobal THEN
      ' // Lock the memory
      pGlobalBuffer = GlobalLock(hGlobal)
      IF pGlobalBuffer THEN
         ' // Copy the image from the resource file to global memory
         CopyMemory pGlobalBuffer, pResourceData, imageSize
         ' // Create an stream in global memory
         IF CreateStreamOnHGlobal(hGlobal, %FALSE, pImageStream) = %S_OK THEN
            ' // Create a bitmap from the data contained in the stream
            hStatus = GdipCreateBitmapFromStream(pImageStream, pBitmap)
            pImageStream = NOTHING
   IF pBitmap = 0 THEN GOTO LExit
   ' // Stretching
   IF bStretch THEN
   IF nCount THEN
   di.lpszDocName = VARPTR(wszImageName)
   LOCAL i, x AS LONG
            ' // Draw the image
            IF bStretch THEN
            EndPage(ppd.hDc)
   EndDoc(ppd.hDc)
LExit:
   ' // Cleanup
   IF ppd.hDc THEN DeleteDC(ppd.hDc)
   ' // Unlock and free the global memory
   IF pGlobalBuffer THEN GlobalUnlock(pGlobalBuffer)
   IF hGlobal THEN GlobalFree(hGlobal)
   ' // Shutdown GDI+
File: GdipUtils.inc
' Prints the specified resource image using the current default printer and printer settings.
' Parameters:
FUNCTION GdiPlusPrintResourceImage(BYVAL hInstance AS DWORD, BYREF wszImageName AS WSTRINGZ, OPTIONAL BYVAL bStretch AS LONG, BYVAL nStretchMode AS LONG) AS LONG
   LOCAL nRet AS LONG
   LOCAL hdc AS DWORD
   LOCAL hr AS LONG
   LOCAL wID           AS WORD
   LOCAL dwID          AS DWORD
   IF hGlobal THEN
   ' // Stretching
   IF bStretch THEN
   IF nCount THEN
   LOCAL i, x AS LONG
            ' // Draw the image
            IF bStretch THEN
            EndPage(hdc)
   EndDoc(hdc)
LExit:
   ' // Cleanup
   ' // Shutdown GDI+
File: AfxWin.inc
' Checks if the specified URL exists.
' Parameters:
' - bstrUrl = URL to check.
' - vTimeout = Optional. Number of seconds to wait. The default value is -1 (infinite).
' Return value: TRUE or FALSE
' To retrieve extended error information, call GetLastError. The error code is returned as
' an HRESULT code to allow the use of OBJRESULT$ to get a localized description of it.
FUNCTION AfxUrlExists (BYVAL bstrUrl AS WSTRING, OPTIONAL BYVAL vTimeout AS VARIANT) AS LONG
   LOCAL pWHttp AS IWinHttpRequest
   LOCAL iSucceeded AS INTEGER
   ' // Creates an instance of the HTTP service
   pWHttp = NEWCOM "WinHttp.WinHttpRequest.5.1"
   IF ISNOTHING(pWHttp) THEN
      SetLastError %E_NOINTERFACE
   TRY
      ' // Opens an HTTP connection to an HTTP resource
      pWHttp.Open "GET", bstrUrl
      ' // Sends an HTTP request to the HTTP server
      pWHttp.Send
      ' // Wait for response
      iSucceeded = pWHttp.WaitForResponse(vTimeout)
      IF iSucceeded THEN
         ' // If it exists, pWHttp.Status returns a value of 200 and pWHttp.StatusText a value of "OK"
         ' // If it does not exist, pWHttp.Status returns a value of 404 and pWHttp.StatusText a value of "Not Found"
         IF pWHttp.Status = 200 THEN FUNCTION = %TRUE
         SetLastError HRESULT_FROM_WIN32(%ERROR_TIMEOUT)
   CATCH
      SetLastError OBJRESULT
   END TRY
File: AfxWin.inc
' Retrieves the version of the specified system DLL.
FUNCTION AfxGetDllVersion (BYVAL bstrDllName AS WSTRING) AS CURRENCYX
   LOCAL pvsffi AS VS_FIXEDFILEINFO PTR
   LOCAL pVerInfo AS DWORD
   LOCAL dwHandle AS DWORD
   LOCAL dwVersion AS DWORD
   LOCAL cbLen AS DWORD
   LOCAL wMajor AS WORD
   LOCAL wMinor AS WORD
   cbLen = GetFileVersionInfoSize(BYCOPY bstrDllName, dwHandle)
   IF cbLen THEN
      pVerInfo = HeapAlloc(GetProcessHeap, %HEAP_ZERO_MEMORY, cbLen)
      IF pVerInfo THEN
         IF GetFileVersionInfo(BYCOPY bstrDllName, dwHandle, cbLen, BYVAL pVerInfo) THEN
            IF VerQueryValue(BYVAL pVerInfo, "\", BYVAL VARPTR(pvsffi), cbLen) THEN
               wMajor = HI(WORD, @pvsffi.dwFileVersionMS)
               wMinor = LO(WORD, @pvsffi.dwFileVersionMS)
         HeapFree GetProcessHeap, 0, pVerInfo
   FUNCTION = wMajor + wMinor / 100
File: AfxWin.inc
' Retrieves the path of the specified system DLL.
FUNCTION AfxGetDllPath (BYVAL bstrDllName AS WSTRING) AS WSTRING
   LOCAL hLib AS DWORD
   LOCAL wszPath AS WSTRINGZ * %MAX_PATH
   hLib = LoadLibraryW(BYCOPY bstrDllName)
   IF hLib THEN
      GetModuleFileNameW(hLib, wszPath, SIZEOF(wszPath))
      FreeLibrary hLib
   FUNCTION = wszPath
' Unscales an horizontal coordinate according the DPI (dots per pixel) being used by the application.
FUNCTION AfxUnScaleX (BYVAL cx AS SINGLE) AS SINGLE
   LOCAL hDC AS DWORD
   hDC = GetDC(%NULL)
   FUNCTION = cx / (GetDeviceCaps(hDC, %LOGPIXELSX) / 96)
   ReleaseDC %NULL, hDC
' Unscales a vertical coordinate according the DPI (dots per pixel) being used by the application.
FUNCTION AfxUnScaleY (BYVAL cy AS SINGLE) AS SINGLE
   LOCAL hDC AS DWORD
   hDC = GetDC(%NULL)
   FUNCTION = cy / (GetDeviceCaps(hDC, %LOGPIXELSY) / 96)
' Returns the version of GdiPlus.dll
FUNCTION GdiPlusDllVersion () AS CURRENCYX
   cbLen = GetFileVersionInfoSize("GDIPLUS.DLL", dwHandle)
   IF cbLen THEN
      IF pVerInfo THEN
         IF GetFileVersionInfo("GDIPLUS.DLL", dwHandle, cbLen, BYVAL pVerInfo) THEN
