oops
Started by Brice Manuel, April 06, 2014, 01:12:17 AM
Brice Manuel
I had three forums open in different tabs, posted in the wrong one by mistake.  Sorry.
Elias Montoya
 But i liked it. :)
And i didnt even had to skip anything. You should show it to all.
Brice Manuel
Gets confusing when so many forums run the same forum software and the same themes.  When you have 20/200 vision, it can be hard to tell the difference sometimes.  LOL
Thanks for your kind words.  If you liked it check your PM, posted a new one today.
