Author Topic: oops  (Read 1280 times)
Brice Manuel
oops
« on: April 06, 2014, 12:42:17 AM »
I had three forums open in different tabs, posted in the wrong one by mistake.  Sorry.
« Last Edit: April 06, 2014, 04:32:00 AM by Brice Manuel »
Elias Montoya
  • Feeling like creating a Linux compiler. :)
Re: oops
« Reply #1 on: April 06, 2014, 06:18:06 PM »
 But i liked it. :)
 And i didnt even had to skip anything. You should show it to all.
Brice Manuel
Re: oops
« Reply #2 on: April 06, 2014, 11:10:44 PM »
Gets confusing when so many forums run the same forum software and the same themes.  When you have 20/200 vision, it can be hard to tell the difference sometimes.  LOL
Thanks for your kind words.  If you liked it check your PM, posted a new one today.
