resources
Started by paulDiagnos, January 24, 2006, 11:51:56 AM
paulDiagnos
Hi all,
In filefly how do you add a file ( any file not just icons) as a resource.
i read the help with regard to adding rc module ( a blankfile) im sure a few lines of text in the file gets me what i want but the solution aludes me in my seaches of the forums.
i then take it that when the file has been added the normal winapi commands will let me get at it
thanks Paul
To add a new resource file to FireFly you simply need to select "Project", "Add Resource Module". You can then add whatever you want into this resource file. When you compile your application, FireFly will combine your resource file with the default FireFly resource to create one final resource file.
