A Richedit question
Started by JR Heathcote, March 15, 2006, 09:32:44 PM
JR Heathcote
How does one determine the number of lines per page in a Richedit control?
Currently I'm using the following code to determine the lines per page:
Sub GetFontMetrics(ByVal hCtl As Dword, _
                       ByVal sText As String, _
                       CX As Long, _
                       CY As Long, _
                       Optional ByVal sPad As String)
 LOCAL hDC AS DWORD
 LOCAL hFnt AS DWORD
 LOCAL uSize AS SIZEL
 sText = sText + sPad     'Pad text, make sure we have enough width.
 hDC = GetDC(hCtl)
 DIALOG SEND hCtl, %WM_GETFONT, 0, 0 TO hFnt
 hFnt = SelectObject(hDC, hFnt)
 GetTextExtentPoint32 hDC, BYVAL STRPTR(sText), LEN(sText), uSize
 SelectObject hDC, hFnt
 ReleaseDC hCtl, hDC
 CX = uSize.cx
 CY = uSize.cy
And...
Function GetLinesPerPage(ByVal hCtl As Dword) As Long
 LOCAL CX AS LONG
 LOCAL CY AS LONG
 LOCAL lPageRows AS LONG
 LOCAL rc AS RECT
 GetWindowRect hCtl, rc
 Call GetFontMetrics(hCtl, "Dummy", CX, CY)
 lPageRows = FIX((rc.nBottom - rc.nTop) / CY)
 FUNCTION = lPageRows
The only problem is the value returned is just about 60% of the total lines per page for the Richedit control.  Obviously the uSize.CY value being returned is too large to calculate the correct value.  Tried looking in POFFS and on line, but nothing I found seems to cover this issue.
TIA
I haven't researched your question but your code does look good except for the DIALOG SEND message. Have you tried using the SendMessage instead:
hFnt = SendMessage( hCtl, %WM_GETFONT, 0, 0 )
