Author Topic: shdocvw.dll and xp  (Read 295 times)
paulDiagnos
  • Guest
shdocvw.dll and xp
« on: April 30, 2007, 06:59:17 AM »
Hi guys,
Trying to use the active controls so i can disply some HTML.
the big problem is i cant follow the tutriol about adding the shdocvw.dll because its not in my list.
im using FF version 2.80. i usually use firefox but i do have the new explorer in stalled.
hope you can help
Thanks Paul
paulDiagnos
  • Guest
Re: shdocvw.dll and xp
« Reply #1 on: April 30, 2007, 07:03:31 AM »
beat you too it guys.. I had to register it ...
start -> run -> regsvr32 c:\windows\system\shdocvw.dll
