Author Topic: Opening Forms from within FF_WinMain hangs app.  (Read 272 times)
Elias Montoya
  • Guest
« on: August 25, 2007, 11:21:05 PM »
 Paul, i have a login form that i dotn want to call every time i run my program
while i debug my app, si , i didnt made the login form the main form.
 Instead, i did it by adding:
Call Login_Show(0, %TRUE)
In FF_WinMain, but after Login_Show() finishes, nothing continues to happen.
The app remains "running" until i close it from the task manager.
 If i REM the Login_Show() from FF_WinMain(), everything else works fine.
is this a docummented behaviour? or did i hit something?
 BTW, if i make the Login_Show() the default form, everything works perfect, i just
dont want to see the login screen while debugging.
  • Guest
Re: Opening Forms from within FF_WinMain hangs app.
« Reply #1 on: August 25, 2007, 11:35:47 PM »
Elias, you can not open a form during FF_WinMain because there is no message pump running at that point. Try the suggestion in the following thread: http://planetsquires.com/support/index.php?topic=1791.0
Elias Montoya
  • Guest
« Reply #2 on: August 25, 2007, 11:43:36 PM »
 I see. Thanx paul, ill read that and see what i can do. :)
