What is STN_CLICKED
Started by Robert E. DeBolt, September 10, 2007, 01:06:49 AM
Robert E. DeBolt
as in Function LOYALTY_PICTURE1_STN_CLICKED?
mikedoty
#1
STN_CLICKED Notification
The STN_CLICKED notification message is sent when the user clicks a static control that has the SS_NOTIFY style. The parent window of the control receives this notification message through the WM_COMMAND message.
Syntax
Copy Code
STN_CLICKED
    WPARAM wParam
    LPARAM lParam;
Parameters
wParam
The low-order word is a static control identifier. The high-order word is the notification message.
lParam
Handle to the static control.
Return Value
http://msdn2.microsoft.com/en-us/library/ms651161.aspx
No return value.
Robert E. DeBolt
Thank you, Mike, for the info.
