I am converting my PB projects to use the FireFly IDE. I continue to get these weird resource errors when embedding simple text files as a resource. These textfiles are the "CONTROL" scripts for my game graphics engine. They enable the game engine to create textboxes and listbox controls that overlay your game. Its simple text, but the resource compile continues to crash.
When I use the standard PB compilers it works perfectly.
SetVal {TB_NAME$, NAME$}
SetVal {TB_PARENT$, PARENT$}
SetVal {TB_CAPTION$, CAPTION$}
SetVal {TB_ENABLED$, ENABLED$}
SetVal {TB_COLOR$, COLOR$}
SetVal {TB_FONT$, FONT$}
SetVal {TB_RESIZE$, RESIZE$}
SetVal {TB_LAYER%, LAYER%}
SetVal {TB_STYLE(0-7)%, STYLE%}
SetVal {TB_WORDWRAP$, WORDWRAP$}
SetVal {TB_VRESIZE$, VRESIZE$}
SetVal {TB_LEFT%, LEFT%}
SetVal {TB_TOP%, TOP%}
SetVal {TB_WIDTH%, WIDTH%}
SetVal {TB_HEIGHT%, HEIGHT%}
SetVal {TB_DRAG$, DRAG$}
SetVal {TB_BLT$, BLT$}
BEGIN:#TB_NAME$#
TYPE = TEXT
PARENT = #TB_PARENT$#
POS = #TB_LEFT%#, #TB_TOP%#
SIZE = #TB_WIDTH%#,#TB_HEIGHT%#
BLT = #TB_BLT$#
LAYER = #TB_LAYER%#
CANDRAG = #TB_DRAG$#
CANEDIT = TRUE
TEXTWRAP = #TB_WORDWRAP$#, #TB_VRESIZE$#
IMAGE = border#TB_STYLE(0-7)%#.res
If {TB_STYLE(0-7)% > 0}
BORDER = TRUE, 10
EndIf:{TB_STYLE(0-7)% > 0}
ENABLED = #TB_ENABLED$#
EVENTS = TRUE
CAPTION = #TB_CAPTION$#
FONT = #TB_FONT$#
FONTCOLOR = #TB_COLOR$#
TEXTPOS = 1, 1
EVENTS:BEGIN
On_Change:
SetVal {#TB_NAME$#.TEXT$, EMT_CAPTION$}
EndEnc
EVENTS:END
END:#TB_NAME$#
DelVarsLike {TB_}
DelVarsLike {CSYS_}
This is the EXACT resource that fails in FireFly. I don't know why it would fail, its only TEXT. When I add the resource I added this line.
TEXTBOX.OBJ RCDATA "G:\Development\PROJECTS\Driver\Includes\RESOURCES\TEXTBOX.MOTION"
I have tons of the .MOTION files used for dialogs, listboxes, and all the normal GUI objects you'd find in a game, but there are about 10 of them that fail. This is a sample of one of them. Any idea?
Tye
