Ownerdrawn combobox....
Started by Elias Montoya, March 17, 2008, 04:12:47 AM
Elias Montoya
Paul i cant get an ownerdrawn combobox to work, the items in the list are drawn correctly,
but it seems like i am not receiving the notification message to owner draw the text when
the combobox is closed...
Do you have an example?
Here is an example based on Borje's color selector combobox:
' Basic QB color function.
Function GetQBColor( ByVal c As Long ) As Long
  Select Case c
     Case  0 : Function = RGB(0,0,0)       ' Black
     Case  1 : Function = RGB(0,0,128)     ' Blue
     Case  2 : Function = RGB(0,128,0)     ' Green
     Case  3 : Function = RGB(0,128,128)   ' Cyan
     Case  4 : Function = RGB(196,0,0)     ' Red
     Case  5 : Function = RGB(128,0,128)   ' Magenta
     Case  6 : Function = RGB(128,64,0)    ' Brown
     Case  7 : Function = RGB(196,196,196) ' Light Gray
     Case  8 : Function = RGB(128,128,128) ' Gray
     Case  9 : Function = RGB(0,0,255)     ' Light Blue
     Case 10 : Function = RGB(0,255,0)     ' Light Green
     Case 11 : Function = RGB(0,255,255)   ' Light Cyan
     Case 12 : Function = RGB(255,0,0)     ' Light Red
     Case 13 : Function = RGB(255,0,255)   ' Light Magenta
     Case 14 : Function = RGB(255,255,0)   ' Yellow
     Case 15 : Function = RGB(255,255,255) ' Bright White
Function FORM1_WM_CREATE ( _
                         hWndForm As Dword, _  ' handle of Form
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Black"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Blue"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Green"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Cyan"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Red"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Magenta"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Brown"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Gray"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Gray"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Blue"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Green"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Cyan"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Red"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Light Magenta"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Yellow"
   FF_ComboBox_AddString HWND_FORM1_COMBO1, "Bright White"
   FF_ComboBox_SetCurSel HWND_FORM1_COMBO1, 0
Function FORM1_CUSTOM ( _
   Local lpdis  As DRAWITEMSTRUCT Ptr
   Local rct    As Rect
   Local zTxt   As Asciiz * 80
   Local hBrush As Long
   Select Case wMsg
     Case %WM_DRAWITEM
        lpdis = lParam
        If @lpdis.itemID = &HFFFFFFFF& Then Exit Function
        Select Case @lpdis.itemAction
           Case %ODA_DRAWENTIRE, %ODA_SELECT
              ' CLEAR BACKGROUND
              FillRect @lpdis.hDC, @lpdis.rcItem, GetSysColorBrush(%COLOR_WINDOW)
              ' GET/DRAW TEXT
              SendMessage  @lpdis.hWndItem, %CB_GETLBTEXT, @lpdis.itemID, VarPtr(zTxt)  'Get text
              SetBkColor   @lpdis.hDC, GetSysColor(%COLOR_WINDOW)            'Set text Background
              SetTextColor @lpdis.hDC, GetSysColor(%COLOR_WINDOWTEXT)        'Set text color
              rct = @lpdis.rcItem
              rct.nLeft = 28
              DrawText @lpdis.hDC, zTxt, Len(zTxt), rct, %DT_SINGLELINE Or %DT_LEFT Or %DT_VCENTER
              ' SELECTED ITEM
              If (@lpdis.itemState And %ODS_SELECTED) Then      'if selected
                 If (@lpdis.itemState And &H1000) = 0 Then      'if not %ODS_COMBOBOXEDIT (= &H1000)
                    rct.nLeft   = 26 : rct.nRight = @lpdis.rcItem.nRight 'Set cordinates
                    rct.ntop    = @lpdis.rcItem.ntop
                    rct.nbottom = @lpdis.rcItem.nbottom
                    InvertRect @lpdis.hDC, rct                  'invert area around text only
                 DrawFocusRect @lpdis.hDC, @lpdis.rcItem        'and draw a focus rectangle around all
              ' PAINT COLOR RECTANGLE (using RoundRect for nicer looks.. :-)
              If (@lpdis.itemState And &H1000) Then             'if %ODS_COMBOBOXEDIT (= &H1000)
                 rct.nLeft   = 4 : rct.nRight = 24              'Set cordinates
              Else
                 rct.nLeft   = 3 : rct.nRight = 23              'a tiny bit to the left in list..
              rct.ntop    = @lpdis.rcItem.ntop + 2
              rct.nbottom = @lpdis.rcItem.nbottom - 2
              hBrush = CreateSolidBrush(GetQBColor(@lpdis.itemID)) 'Create brush with proper color
              hBrush = SelectObject(@lpdis.hDC, hBrush)         'Select brush into device context
              RoundRect @lpdis.hDC, rct.nLeft, rct.ntop, rct.nRight, rct.nbottom, 3, 3  'Draw
              DeleteObject SelectObject(@lpdis.hDC, hBrush)     'Select old brush back and delete new one
        Function = %TRUE : Exit Function
Elias Montoya
