Author Topic: Button Color  (Read 198 times)
BudDurland
  • Guest
Button Color
« on: April 25, 2008, 06:14:43 PM »
All I need is for one push button on my form to be green with black letters.  I don't need it to change colors based on it's state, or any of that.
Is an image button really the only way out? I tried that, found that the colors sometimes don't display correctly.  Any advice appreciated.
  • Guest
Re: Button Color
« Reply #1 on: April 25, 2008, 07:50:54 PM »
Did you try Borje's RRButton? FireFly has the RRButton in the ToolBox.
BudDurland
  • Guest
Re: Button Color
« Reply #2 on: April 26, 2008, 10:54:05 PM »
RRButton is just what I need!
Silly me..  I saw the control on the FireFly pallet, but didn't think it was already built in.  After a couple broken links, I found RRButton & downloaded it, but an initial glance that the comments in the source made me think it was simply a replacement for the standard image button, so I didn't try it out.
Thanks for the help!
