FF_Control_GetCheck And Select Case
Started by Robert Dunn, June 07, 2008, 06:16:34 PM
Robert Dunn
From the help section of FireFly:
'-- FF_Control_GetCheck -------------------------------------------
'   Gets the check state of a CheckBox control.
'   hWndControl: Handle of control (e.g. HWND_FORM1_CHECK1)
'   Returns:     %TRUE if checked or %FALSE if unchecked
Function FF_Control_GetCheck (ByVal hWndControl As Dword) As Long
I have A check box on a form "CHECK1"   I'm trying to use a select case statement
to tell me when there is a check in the check box.   Using the code from the help file above  I Have not been able to tell the status of the check box.   Here is my current code for this function:
Function FORM1_IMAGEBUTTON4_BN_CLICKED ( _
'Play Button
FF_Control_GetCheck HWND_FORM1_CHECK1
Select Case  GetCheck
Case %FALSE
FF_TextBox_SetText HWND_FORM1_Label2, "        Playing..."
Case %TRUE
FF_TextBox_SetText HWND_FORM1_Label2, "Playing...(Continous)"
This code never seems to work no matter what I set the select case statement to.
I'm guessing here that FF_Control_GetCheck Is some type of a variable to store the returned value in, But I can't seem to get the variable set correctly in case statement.
Could somebody please point me in the right direction ?
Thanks
Robert Dunn
Oh my Gawd,  I feel so stupid..   Lol   I tried this befor:
Select Case   FF_Control_GetCheck HWND_FORM1_CHECK1  This did not work.
Then I put quotes around it:  Select Case   FF_Control_GetCheck (HWND_FORM1_CHECK1)
Now it works  ;D
Guess I have some serious reading to do...
