Bitmap in listview
Started by paulDiagnos, June 19, 2008, 08:41:46 AM
paulDiagnos
Another Question.. sorry.
Is it possible to (instead of icons) populate a listview with bitmap images.
and if so how
thanks again paul.
paulDiagnos
After all my experimenting, I have concluded I am a moron.
the reason this code didnt work was because the bmp i wanted to display 1.bmp
was not in the DIR!! grr so mad
hImageList = ImageList_Create(128, 128, %ILC_COLORDDB, 2, 1)     ' use 32, 32 for Large Icons
ImageList_SetBkColor hImageList, GetSysColor(%COLOR_WINDOW)
hTemp   = LoadImage(ByVal %Null, ByCopy "1.bmp", %IMAGE_BITMAP, 0, 0,%LR_LOADTRANSPARENT Or %LR_LOADMAP3DCOLORS Or %LR_DEFAULTSIZE     Or %LR_LOADFROMFILE)
iImage1 = ImageList_Add(hImageList,hTemp , 0 )
DestroyIcon hTemp
Quote from: paulDiagnos on June 19, 2008, 11:34:00 AM
:D
Also, instead of DestroyIcon you should use DeleteObject because you want to release the handle of a bitmap rather than an icon.
paulDiagnos
Thanks :-) didnt spot that one.
me thinks im having a bad day. haha
cheers Paul.
paulDiagnos
Also Any chance of a example on how to use drag and drop with this, (im dragging acros to a treeview from a list view)
I found the zip file on the site that was recommented, but not sure how to use in in FF
cheers Paul.
