User Tools
Started by RhodyRich, February 19, 2009, 10:52:58 AM
RhodyRich
I like the user tools provided with FireFly. I also use "Gotcha". What other user tools do you use or recommend?
The only tool that I have used is an ASCII value viewer in order to quickly look up ascii numbers. I have attached it to this post.
I think that I set it up with a hot key like Ctrl+1 or something.
Note: The "parameters" line in the current FF2 2.95 is broken. If you need to pass parameters to your Tool then let me know and I will email you a fix. Also, the hot key accelerator for Tools is part of the fix.
RhodyRich
Tried the ASCII code viewer. Works great. Thanks.
