Button double clicks
Started by Elias Montoya, May 27, 2009, 06:35:41 PM
Elias Montoya
Is there a way to remove the CS_DBLCLKS style from a button's class before it is created by firefly? Or can it be changed at run time?
I would like to be able to do it from within firefly instead of having to add my own SDK code.
Thanx. :)
You should be able to change it at runtime.
Try putting the following in the WM_CREATE message handler to remove the class style from a command button.
    Local hClassStyles As Dword
    hClassStyles = GetClassLong( HWND_FORM1_COMMAND1, %GCL_STYLE )
    SetClassLong HWND_FORM1_COMMAND1, %GCL_STYLE, hClassStyles And (Not %CS_DBLCLKS)
Elias Montoya
 Thanx paul, i had so much things on my head i couldn't remember that. :)
