Abort a form
Started by BudDurland, June 03, 2009, 03:41:34 PM
BudDurland
Is there a way to abort loading/displaying a form?  I though returning %True from the _wm_create function would do it, but apparently not.  The best I can think of is to post a message to the form to close.
I think you're right. Post a message.
If it is a popup Form that you're about to show then you could initially create that Form with WS_VISIBLE unchecked at design time. That way you won't get an annoying flash of the Form on scree before it is closed.
%MSG_USER_CLOSEFORM = %WM_USER + 1
Function FORM2_WM_CREATE ( _
                         hWndForm As Dword, _  ' handle of Form
   PostMessage hWndForm, %MSG_USER_CLOSEFORM, 0, 0
Function FORM2_CUSTOM ( _
   Select Case wMsg
      Case %MSG_USER_CLOSEFORM
         FF_CloseForm hWndForm
