Author Topic: Egrid32 - Creating XML file  (Read 677 times)
Anonymous
  • Guest
« on: April 07, 2004, 03:47:20 PM »
Hello, i already made an xml file to port Egrid32 functions to firefly,
however i had a hard time using "QB,xxx" to set a color for the control, i dont wknow why it didnt work, but using "SYS,xxx" works, any ideas?
Elias :)
Patrice Terrier
  • Guest
« Reply #1 on: April 07, 2004, 05:43:43 PM »
Elias,
You should use your real name :!:
  • Guest
« Reply #2 on: April 07, 2004, 05:53:01 PM »
I would prefer that people not use handles:
http://www.planetsquires.com/forums/viewtopic.php?t=9
However, if you must use a handle then you will need to put your full name in the signature line.
:thumbsup:
