Author Topic: XP Theme colors  (Read 893 times)
fraser-portwood
  • Guest
XP Theme colors
« on: April 13, 2004, 06:45:11 PM »
I thought i was having a display problem on my XP home computer, but I now release where the problem is.
The Tabcontrol is a 3d object and therefore recv the background color for 3d object, should not the tabchild there adopt the backcolor of the tabcontrol to keep in line with the XP color theme.
Fraser
Anonymous
  • Guest
XP Theme colors
« Reply #1 on: May 08, 2004, 05:16:20 PM »
You need to call EnableThemeDialogTexture for each tab page dialog...
CALL EnableThemeDialogTexture(hDlgTabpage, %ETDT_ENABLETAB)
  • Guest
XP Theme colors
« Reply #2 on: May 08, 2004, 05:46:24 PM »
Quote from: "Lance"
Thanks Lance, I appreciate the help. I will make the internal code change.
