Minor problem with RichEdit control
Started by Martin Francom, November 19, 2009, 08:09:36 PM
Martin Francom
In the RichEdit Control  you can copy & paste using keyboard shortcut  ie:
   Ctrl-Insert  to copy
   Shift-Insert to paste
But you can NOT use Right Mouse Click to get the normal edit menu.  It would be nice to have RichEdit control respond normally to a right mouse click.
Hi Marty,
This is not a FireFly problem, it is actually a Windows behaviour. Right-click popup menus do not show in RichEdit controls like they do in standard Edit controls (ie. TextBoxes).
Here is code that I use to display and respond to a popup menu in a RichEdit. It is from the Project Notes form in FireFly itself.
%IDC_RICHEDIT_UNDO  = %WM_USER + 101
%IDC_RICHEDIT_CUT   = %WM_USER + 102
%IDC_RICHEDIT_COPY  = %WM_USER + 103
%IDC_RICHEDIT_PASTE = %WM_USER + 104
'//  Create and show the right-click popup menu for the RichEdit textboxes
Function ShowRichEditPopup() As Long
    If g.hRightClickPopup Then DestroyMenu g.hRightClickPopup
    g.hRightClickPopup = CreatePopupMenu()
        AppendMenu g.hRightClickPopup, %MF_STRING, %IDC_RICHEDIT_UNDO,  "Undo"
        AppendMenu g.hRightClickPopup, %MF_SEPARATOR, 0, ""
        AppendMenu g.hRightClickPopup, %MF_STRING, %IDC_RICHEDIT_CUT,   "Cut"
        AppendMenu g.hRightClickPopup, %MF_STRING, %IDC_RICHEDIT_COPY,  "Copy"
        AppendMenu g.hRightClickPopup, %MF_STRING, %IDC_RICHEDIT_PASTE, "Paste"
Function FRMPROJNOTES_CUSTOM ( _
   Select Case wMsg
      Case %WM_CONTEXTMENU
          ShowRichEditPopup
          Local pt As PointApi
          GetCursorPos pt
          TrackPopupMenu g.hRightClickPopup, %TPM_LEFTALIGN Or _
                              %TPM_LEFTBUTTON, pt.x, _
                              pt.y, 0, hWndForm, ByVal %Null
Function FRMPROJNOTES_WM_COMMAND ( _
                                 hWndControl  As Dword, _  ' handle of Control
                                 wNotifyCode  As Long,  _  ' notification code
                                 wID          As Long   _  ' item, control, or accelerator identifer
   Select Case wID
      Case %IDC_RICHEDIT_UNDO
         SendMessage HWND_FRMPROJNOTES_RICHEDIT1, %EM_UNDO, 0, 0
      Case %IDC_RICHEDIT_CUT
         SendMessage HWND_FRMPROJNOTES_RICHEDIT1, %WM_CUT, 0, 0
      Case %IDC_RICHEDIT_COPY
         SendMessage HWND_FRMPROJNOTES_RICHEDIT1, %WM_COPY, 0, 0
      Case %IDC_RICHEDIT_PASTE
         SendMessage HWND_FRMPROJNOTES_RICHEDIT1, %WM_PASTE, 0, 0
Pedro Marquez
"g" is defined as a global TYPE with hRightClickPopup as one of its members. Something like this:
Type GLOBALS_TYPE
   hRightClickPopup As DWord
End Type
Global g As GLOBALS_TYPE
Pedro Marquez
#4
This is good and sorry for reviving the topic.
It could bring back series version of ff3
can be done globally for all
Pedro Marquez
Just need to act alone in this window RICHEDIT1
If wParam = HWND_FORM1_RICHEDIT1 Then
