Dissable Button
Started by Jean-pierre Leroy, April 15, 2004, 12:17:59 PM
Jean-pierre Leroy
OK somebody had to be first
Having a bit of trouble moving over from DDT . I can't find, and yes I really have looked, for the function to disable a button. What I need is the button version of this menu function
EnableMenuItem Function
The EnableMenuItem function enables, disables, or grays the specified menu item.
Syntax
BOOL EnableMenuItem(
   HMENU hMenu,
   UINT uIDEnableItem,
   UINT uEnable
Or DDT version
CONTROL DISABLE hDlg, id&
Michael
George Bleck
EnableWindow hButton, bAction
hButton is the handle of the button (or listview, or combobox, or editbox...)
BAction is %TRUE (enable) or %FALSE (disable)
Jean-pierre Leroy
Thanks George
Up and running
Michael
