3.04 bugs
Started by Robert Rioja, November 30, 2009, 11:08:20 AM
Robert Rioja
I have a program that I have been successfully compiling with FF 2.99 to 3.03 but 3.04 crashes all the time.  I am starting the project over again from scratch to see where the problem starts.  I will report my findings.
Another problem is that the tab spacing does not work.  I am using 3.04 and I don't know if previous version also had the problem.  If in the Tools > Environment Options > Code Editor > Tab Size you set it to a number (like 3) then every time you press the Tab key it inserts 3 spaces.  It does not add spaces to the next multiple of 3 so that text will line up in columns.  This makes the tab key virtually useless.
Nathan Durland
I am also seeing the same behavior with the TAB key
Gary Stout
I think Paul mentioned in another thread that this was done intentionally in FF3.x. He can probably explain why.
Gary
