Another COM Thing
Started by David Martin, April 20, 2004, 12:25:56 AM
David Martin
Using the Tutorial 2 project.
- Select the Webbrowser OCX/ActiveX object on the form
- Goto Properties tab and select OCX_ProgId property
- Click on the Elipse to open the COM Browser
- Close the COM Browser ( via menu or close box )
- Select OCX_Events on Property page
- Click on Eplipse
I get the error: The 'OCX_ProgID' property for this control must be set prior to attempting to generate the related OCX events.
Well ... the OCX_ProgID property still says: Shell.Explorer.1
David
From your description it appears that the Prog_ID field is not getting cleared, visually, in the PropertyList. Try clicking on the Form and then re-clicking on the OCX. Does the property now change its value?
I will look into this as soon as I get back to the source code.
David Martin
Quote from: TechSupportFrom your description it appears that the Prog_ID field is not getting cleared, visually, in the PropertyList. Try clicking on the Form and then re-clicking on the OCX. Does the property now change its value?
Tried this, and everything else I could think of to force a refresh.  This may be tied to the not seeing anything in the COM browser left side panel.
Quote from: TechSupportI will look into this as soon as I get back to the source code.
Ok.
