Removing forms from a project
Started by Stuart Sanders, April 24, 2004, 11:53:42 AM
Stuart Sanders
I'm still playing around with Firefly and came across the following.
I've added a form to a project and then decided I didn't want it in the project anymore.  I used the option under the Project Menu to remove the current form.
I have since been playing around further, but when I look at the code generated by Firefly it still adds in
Is this intentional behaviour, and if so how do I completely remove reference to code modules that are no longer wanted in a project?
Thanks
Stuart
Hi Stuart,
Are you using FireFly 1.03??? There may have been a problem in 1.02 with this type of behaviour (for Modules, not Forms, if I remember correctly).
I have just tested adding and removing Forms from a sample project and the generated code always produces the correct output.
Can anyone else here reproduce Stuart's experience?
Stuart Sanders
Quote from: TechSupportAre you using FireFly 1.03??? There may have been a problem in 1.02 with this type of behaviour (for Modules, not Forms, if I remember correctly).
Its 1.03.
Stuart, I have sent you a private email with some things that I would like for you to try.
