Resize issue with code windows
Started by Haakon Birkeland, April 25, 2004, 07:42:23 AM
Haakon Birkeland
If FF (1.03) is resized, and focus then is changed to different code window, the 'new' window does not seem to be aware that the surrounding window size has changed. This leads to a to small or to big code window, often with missing scrollbars. A repeated resize with the current window on-screen fixes it, so it seems like a/the size check should be placed in a different 'event'.
Hi Haakon,
You are correct. I will fix that for the next update.
