SQLightning problem
Started by Douglas McDonald, February 10, 2010, 07:22:22 PM
Douglas McDonald
Here is a simple app that I'm getting an invalid SET NUMBER error. I can create the DB and add records but I get the error when i try to read records. Sorry this is the first try with SQLightning so I'm stupid
the error is in the FORM1_BOPENDB_BN_CLICKED routine
=======>>> Set Numbers
%snContacts   = 1
%snStationInfo = 2
Function FORM1_BCREATE_BN_CLICKED ( _
  ' ==========>>> SQLitening -- Open
   ' This will open the main database.  We will include the "C" ModChar
   ' which will create the file if it does not already exist. The extension
   ' can be anything you like.  SQLite likes .Db3 while I prefer .Sld -- your
   ' choice.
   slOpen "HamLog.Sld", "C"
  ' ==========>>> SQLitening -- Exe
   ' Begin transaction
   slExe "Begin"
   'MsgBox "begin"
   ' Drop all the main tables if they exist.  We do this because we want
   ' to start with empty tables each time this example is run.  Note that
   ' we do all the drops in one slExe command
   slExe "Drop Table If Exists Customers; Drop Table If Exists Parts;" & _
         "Drop Table If Exists Orders; Drop Table If Exists LineItems"
   ' Create the Contact table.  Note that the CustomerID will be the same value
   ' as the built-in RowID but we do not want a new customer to get the same number
   ' as a deleted one so we add the Autoincrement keyword. We do not assign a type
   ' to Name and City. A great thing about SQLite is that the type of a value is
   ' associated with the value itself, not with the column in which the value is
   ' stored.
   slExe "Create Table Contacts (cID Integer Primary Key Autoincrement, Call_Sign, Fname,Lname)"
   ' Create the Station info table.  Same concept as Customers.
   slExe "Create Table Station_Info (sID Integer Primary Key Autoincrement, Rig, Antenna)"
   slExe "End"
Function FORM1_WM_CREATE ( _
createListHeaders
Sub createListHeaders()
   FF_ListView_InsertColumn( HWND_FORM1_LISTVIEW1, 0, "Call Sign", %LVCFMT_CENTER ,75)
   FF_ListView_InsertColumn( HWND_FORM1_LISTVIEW1, 1, "First Name", %LVCFMT_CENTER ,75)
   FF_ListView_InsertColumn( HWND_FORM1_LISTVIEW1, 2, "Last Name", %LVCFMT_CENTER ,75)
   FF_ListView_InsertColumn( HWND_FORM1_LISTVIEW1, 3, "Rig", %LVCFMT_CENTER ,75)
   FF_ListView_InsertColumn( HWND_FORM1_LISTVIEW1, 4, "Antenna", %LVCFMT_CENTER ,75)
End Sub
Function FORM1_BADDONE_BN_CLICKED ( _
Local Callsign As String
Local Fname As String
Local Lname As String
Local Rig As String
Local Antenna As String
   Callsign= FF_TextBox_GetText( HWND_FORM1_TXTCALLSIGN )
   Fname = FF_TextBox_GetText( HWND_FORM1_TXTFIRSTNAME )
   Lname = FF_TextBox_GetText( HWND_FORM1_TXTLASTNAME )
   Rig =FF_TextBox_GetText( HWND_FORM1_TXTRIG )
   Antenna =  FF_TextBox_GetText( HWND_FORM1_TXTANTENNA )
   ' Begin transaction
   slExe "Begin"
   slExe slBuildInsertOrUpdate("Contacts", Callsign & $Nul & Fname & $Nul & Lname,"Call_Sign,Fname,Lname")
   slExe slBuildInsertOrUpdate("Station_Info", Rig & $Nul & Antenna ,"Rig,Antenna")
    ' End transaction
   slExe "End"
Function FORM1_BOPENDB_BN_CLICKED ( _
  Local Numflds As String
  Local rec As String
  Local i As Long
  ' Process records
   Do While slGetRow(%snContacts)    ' I get the error here
            ' When a row is returned, you use the slF, slFN, slFX, slFNX functions.
            Rec = ""
            For i = 1 To slGetColumnCount
            MsgBox Str$(slGetRow) & "  " & Str$(slGetColumnCount)
                        Rec = Rec & slF(i) & " - "
            Next
            ztrace Rec & $Nul
   Loop
Doug McDonald
KD5NWK
www.redforksoftware.com
In your FORM1_BOPENDB_BN_CLICKED you are trying to slGetRow on nothing! You need to create a recordset first by issuing an slSel call. Once slSel finishes then a recordset will exist. You iterate over that recordset using slGetRow.
Also, in your FORM1_BCREATE_BN_CLICKED you are slOpen but not slClose. This means that if you try to do the FORM1_BOPENDB_BN_CLICKED without first doing the create then the database will not be open. In your FORM1_BOPENDB_BN_CLICKED you should slOpen, slSel, slGetRow and finally slClose.
Hope that solves the problem. :)
Douglas McDonald
Thank you Paul I'll give it a try. Sorry to bother you, I'll get the hang of SQLightning soon
Doug McDonald
KD5NWK
