ListView with muli-line header
Started by James Fuller, February 15, 2010, 02:06:12 PM
James Fuller
Here is a Listview Demo project that has a multi-Line header.
The original code was  By Jules Marchildon April/2002 and Inspired by Mark Newman
James
I don't use Jose Includes and the custom options in the AppStart stopped it from compiling too.  After I remove that it compiles, but the column headers are blank except one word in Blue about 3/4 the way into the columns.
Jean-pierre Leroy
Hello James,
Thank you for this demo; but on my system I can't see the multi-line header.
See the screenshot.
Jean-Pierre
James Fuller
No Idea what the problem is.
OS here is Win7(64)
James
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Jean-pierre Leroy
It works if I disable the "Theme support" for the project.
Jean-Pierre
Quote from: Jean-Pierre Leroy on February 15, 2010, 06:27:39 PM
See - told you (in the other thread about customdraw and XP Themes.
#7
Using a big font to increase the header height is a hack that doesn't work with XP themes.
A more straightforward way is to process the HDM_LAYOUT message, fill the WINDOWPOS structure with the appropriate size and position of the header control, and change the top position of the rectangle that the header control will occupy.
   CASE %HDM_LAYOUT
      LOCAL phdl AS HDLAYOUT PTR
      phdl = lParam
      @phdl.@pwpos.hwnd = hwnd
      @phdl.@pwpos.flags = %SWP_FRAMECHANGED
      @phdl.@pwpos.x = @phdl.@prc.nLeft
      @phdl.@pwpos.y = 0
      @phdl.@pwpos.cx = @phdl.@prc.nRight - @phdl.@prc.nLeft
      @phdl.@pwpos.cy = 40   ' --> change me
      @phdl.@prc.nTop = 40   ' --> change me
      FUNCTION = -1
Attached to this post you will find a modified version of Jules' example.
#8
In the James' example, change:
Function HeaderProc( ByVal hWndControl As Dword, _
                       ByVal wMsg   As Dword, _
                       ByVal wParam As Long, _
                       ByVal lParam As Long _
   Local hFont As Long
   Select Case wMsg
      Case %WM_SIZE
         hFont = FF_MakeFontEX("Tahoma",%HEADER_HEIGHT,0,0,0,0)
         SendMessage hWndControl,%WM_SETFONT,hFont,1
         DeleteObject hFont
      Case %WM_LBUTTONDBLCLK
          PostMessage hWndControl,%WM_LBUTTONDOWN,wParam,lParam
          Function = 0
          Exit Function
   Function = FF_SubClassOrig(hWndControl,wMsg,wParam,lParam)
to:
   Select Case wMsg
          Function = 0
          Exit Function
      CASE %HDM_LAYOUT
          phdl = lParam
          @phdl.@pwpos.hwnd = hWndControl
          @phdl.@pwpos.y = 0
          @phdl.@pwpos.cy = 120   ' --> change me
          @phdl.@prc.nTop = 120   ' --> change me
          FUNCTION = -1
James Fuller
