FF_DateAdd adn FF_DateDiff
Started by Paul Squires, October 07, 2010, 12:21:12 PM
Here are two date functions that have been added to FF3 that you will access to once version 3.10 is released.
' FF_DateAdd
' Add or subtract days from a date
' Valid date format: YYYYMMDD, YYYY-MM-DD, YYYY/MM/DD
Function FF_DateAdd( ByVal sDate As String, _
                     ByVal nNumDays As Long _
                     ) As String
   Local sTime As SYSTEMTIME
   Local fTime As FILETIME
   Local nTemp As Quad
   sDate = Retain$( sDate, any "0123456789" )
   sTime.wYear  = Val(Left$(sDate, 4))
   sTime.wMonth = Val(Mid$(sDate, 5, 2))
   sTime.wDay   = Val(Right$(sDate, 2))
   SystemTimeToFileTime sTime, fTime
   MoveMemory ByVal VarPtr(nTemp), ByVal VarPtr(fTime), ByVal SizeOf(fTime)
   ' FileTime returns 100's of NANOSECONDS so you have to adjust
   ' **** IncrValue * 10000000 to convert to Nanoseconds
   nTemp = nTemp + (nNumDays * 86400 * 10000000)  ' #of seconds per day is 86400
   MoveMemory ByVal VarPtr(fTime), ByVal VarPtr(nTemp), ByVal SizeOf(nTemp)
   FileTimeToSystemTime fTime, sTime
   Function = Format$(sTime.wYear, "0000") & _
              Format$(sTime.wMonth, "00") & _
              Format$(sTime.wDay, "00")
Function FF_DateDiff( ByVal sDate1 As String, _
                      ByVal sDate2 As String _
   Local sTime1, sTime2 As SYSTEMTIME
   Local fTime1, fTime2 As FILETIME
   Local nTemp, nTemp1, nTemp2 As Quad
   sDate1 = Retain$( sDate1, Any "0123456789" )
   sDate2 = Retain$( sDate2, Any "0123456789" )
   sTime1.wYear  = Val(Left$(sDate1, 4))
   sTime1.wMonth = Val(Mid$(sDate1, 5, 2))
   sTime1.wDay   = Val(Right$(sDate1, 2))
   SystemTimeToFileTime sTime1, fTime1
   MoveMemory ByVal VarPtr(nTemp1), ByVal VarPtr(fTime1), ByVal SizeOf(fTime1)
   sTime2.wYear  = Val(Left$(sDate2, 4))
   sTime2.wMonth = Val(Mid$(sDate2, 5, 2))
   sTime2.wDay   = Val(Right$(sDate2, 2))
   SystemTimeToFileTime sTime2, fTime2
   MoveMemory ByVal VarPtr(nTemp2), ByVal VarPtr(fTime2), ByVal SizeOf(fTime2)
   ' The difference is the number of nanoseconds between the
   ' two dates. Convert to days.
   nTemp = (nTemp1 - nTemp2) / (86400 * 10000000)
   Function = nTemp
Marc van Cauwenberghe
This is really great Paul. Thank you!!!
Peter House
I have them now.  Why do I need 3.10 ???
Quote from: Peter House on October 15, 2010, 11:40:50 PM
You don't need 3.10. I just meant that the functions will be included int he standard FF3 installation once I finally pop out 3.10.
Peter House
I meant that as a joke.
Apparently it had all the elements of a joke except the humor.
Keep up the good work - I don't need 3.10 but I do look forward to it.
Very nice. Date and Time functions is something that PB never bothered with.
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
John Montenigro
It's been so long since my last burst of programming that I can't remember how to do this...
Is there a way that I can add these 2 functions into FF 3.09?
-John
Peter House
Depending on how you installed, there is a folder either under the install folder or in your My Documents folder called something like "Code Snippets"  You can put them there.
Here are the two functions in a zip. Unpack them into FireFly's codestore. I had put them into the general folder.
..\CodeStore\PowerBASIC\FireFly_Functions\General
Then they are available in the Functions Library  (F8).
(W. C. Fields)
John Montenigro
#9
Thanks for the help! I now have them installed in "General", too!
I'm going to be testing them -- I need to be able to specify a "Remind me" date and time, based on a given date/time, and a specification of weeks, days, hours, and minutes (or a combination).
I need to find out: will this new Date function be able to handle it, if for example, I have a date/time of April 3, 2011 10am, and I need to find the date/time that is 3 Days, 6 Hours, and 45 minutes earlier?
-John
ALSO: I renamed the folder "General" to "_General", so it now appears at the top of the list...
Richard Kelly
Quote from: John Montenigro on February 02, 2011, 01:37:32 PM
Well, in the thread "Date Calculations", I have a function "TimeCalculation" that returns March 31, 2011 at 3:15am. See attachment in first thread.
Rick
John Montenigro
Thanks, Richard,
I've d/l'd the files and will try them out over the weekend.
-John
