DX Studio - I need some help
Started by Paul Squires, March 06, 2011, 03:40:08 PM
A fellow FireFly user is having trouble unloading an OCX from memory when the application ends. The exe process continues to run and stays in memory.
The DX Studio player control can be found here:  http://www.dxstudio.com/download.aspx
A sample project is attached.
Note: If the code in WM_DESTROY is executed elsewhere other than in WM_DESTROY then the control unloads and the exe does not remain in memory.
Any ideas why it won't work properly via the WM_DESTROY handler?
Thanks!
#1
Function FORM1_WM_DESTROY ( _
                          hWndForm      As Dword _  ' handle of Form
   Local pDispatch As IDXStudioPlayer
   ' Get a reference to the DXStudio control and set the properties
   pDispatch = OC_GetDispatch(HWND_FORM1_OCXCONTROL1)
   If IsObject(pDispatch) Then
      pDispatch.ManualShutDown
      pDispatch = Nothing
Do error checking, i.e. check if IsObject(pDispatch) returns true and if pDispatch.ManualShutDown returns true.
Frank Applin
There seems to be a timing issues as to when messages get processed. If I check the return value and pop up a messagebox, the ManualShutdown happens and the executable is not left in memory. If I comment out the messagebox then the executable is still left in memory.
Function FORMMOVECHESSPIECES_WM_CLOSE ( _
   Local ret As Long
   pDispatch = OC_GetDispatch(HWND_FORMMOVECHESSPIECES_OCXCONTROL1)
      Call pDispatch.ManualShutdown() To ret
      MsgBox "return value " + Str$(ret)
      pDispatch = Nothing
Cho Sing Kum
Will a DoEvent at the right place help?
Maybe it is slow closing and when the program finishes can't unload it because it is still busy. Try to do the shut down in WM_CLOSE instead of WM_DESTROY.
Frank Applin
It leaves it in memory in either WM_CLOSE or WM_DESTROY. I'm trying to re-create it in straight PB and it seems to get unloaded fine from straight PB.
Frank Applin
This is based on one of Jose' examples (Thanks, Jose') and works great. I don't even do a shutdown at all.
  #DIM ALL
  #DEBUG ERROR ON
  #INCLUDE "win32api.inc"
  %ID_OCX = 1001
  %ID_NORTH = 1002
  %ID_EAST = 1003
  %ID_SOUTH = 1004
  %ID_WEST = 1005
  %ID_RESET = 1006
  GLOBAL hDlg AS DWORD
  GLOBAL hOcx AS DWORD
  GLOBAL oOcx AS DISPATCH
' ATLAPI_(BOOL) AtlAxWinInit( );
' This function initializes ATL's control hosting code by registering the "AtlAxWin7" and
' "AtlAxWinLic7" window classes plus a couple of custom window messages.
' Return Value: TRUE, if the initialization of the control hosting code was successful; otherwise FALSE.
' Remarks: This function must be called before using the ATL control hosting API. Following a
' call to this function, the "AtlAxWin" window class can be used in calls to CreateWindow or
' CreateWindowEx, as described in the Platform SDK.
  DECLARE FUNCTION AtlAxWinInit LIB "ATL.DLL" ALIAS "AtlAxWinInit" () AS LONG
' inline BOOL AtlAxWinTerm( );
' This function uninitializes ATL's control hosting code by unregistering the "AtlAxWin7" and
' "AtlAxWinLic7" window classes.
' This function simply calls UnregisterClass as described in the Platform SDK.
' Call this function to clean up after all existing host windows have been destroyed if you
' called AtlAxWinInit and you no longer need to create host windows. If you don't call this
' function, the window class will be unregistered automatically when the process terminates.
' Return Value: If the function succeeds, the return value is nonzero.
  DECLARE FUNCTION AtlAxWinTerm () AS LONG
    UnregisterClass ("AtlAxWin", GetModuleHandle(BYVAL %NULL))
' ATLAPI AtlAxGetControl (HWND h, IUNKNOWN** pp);
' Obtains a direct interface pointer to the control contained inside a specified window given its handle.
  DECLARE FUNCTION AtlAxGetControl LIB "ATL.DLL" ALIAS "AtlAxGetControl" _
     ( _
     BYVAL hWnd AS DWORD, _   ' [in] A handle to the window that is hosting the control.
     BYREF pp AS DWORD _      ' [out] The IUnknown of the control being hosted.
  ) AS DWORD
' Puts the address of an object in a variant and marks it as containing a dispatch variable
  SUB AtlMakeDispatch ( _
     BYVAL lpObj AS DWORD, _                        ' Address of the object instance
     BYREF vObj AS VARIANT _                        ' Variant to contain this address
     ) EXPORT
     LOCAL lpvObj AS VARIANTAPI PTR                 ' Pointer to a VARIANTAPI structure
     LET vObj = EMPTY                               ' Make sure is empty to avoid memory leaks
     lpvObj = VARPTR(vObj)                          ' Get the VARIANT address
     @lpvObj.vt = %VT_DISPATCH                      ' Mark it as containing a dispatch variable
     @lpvObj.vd.pdispVal = lpObj                    ' Set the dispatch pointer address
' Converts a Windows error code in a message string
  FUNCTION WinErrorMsg (BYVAL dwError AS DWORD) AS STRING
     LOCAL pBuffer   AS ASCIIZ PTR
     LOCAL ncbBuffer AS DWORD
     LOCAL sText AS STRING
     ncbBuffer = FormatMessage(%FORMAT_MESSAGE_ALLOCATE_BUFFER _
                 OR %FORMAT_MESSAGE_FROM_SYSTEM OR %FORMAT_MESSAGE_IGNORE_INSERTS, _
                 BYVAL %NULL, dwError, BYVAL MAKELANGID(%LANG_NEUTRAL, %SUBLANG_DEFAULT), _
                 BYVAL VARPTR(pBuffer), 0, BYVAL %NULL)
     IF ncbBuffer THEN
         sText = PEEK$(pBuffer, ncbBuffer)
         sText = REMOVE$ (sText, ANY CHR$(13) + CHR$(10))
         LocalFree pBuffer
         sText = "Unknmown error - Code "+ HEX$(dwError, 8)
     FUNCTION = sText
'                                  M A I N     P R O G R A M
' Main dialog callback
  CALLBACK FUNCTION MainDlgProc()
     LOCAL rc AS RECT
     LOCAL r AS LONG
     LOCAL x AS LONG
     LOCAL y AS LONG
     LOCAL xx AS LONG
     LOCAL yy AS LONG
     SELECT CASE CBMSG
        CASE %WM_SIZE
           'GetClientRect CBHNDL, rc
           'x = rc.nLeft : y = rc.nTop
           'xx = rc.nRight - 100 'rc.nLeft
           'yy = rc.nBottom - 100 'rc.nTop
           'MoveWindow hOcx, x, y, xx, yy, %TRUE
        CASE %WM_DESTROY
           PostQuitMessage 0
        CASE %WM_COMMAND
           SELECT CASE CBCTL
              CASE %IDCANCEL
                 IF CBCTLMSG = %BN_CLICKED OR CBCTLMSG = 1 THEN
                    DIALOG END CBHNDL, 0
CALLBACK FUNCTION ButtonResetCallback() AS LONG
    IF CB.MSG = %WM_COMMAND AND CB.CTLMSG = %BN_CLICKED THEN
        '...Process the click event here
        LOCAL temp AS VARIANT
        temp = "scenes.scene_1.script.ResetPieces()"
        OBJECT CALL oOcx.Send(temp)
        FUNCTION = 1
CALLBACK FUNCTION ButtonNorthCallback() AS LONG
        temp = "scenes.scene_1.script.MoveNorth('BlackQueen')"
        FUNCTION = 1
CALLBACK FUNCTION ButtonEastCallback() AS LONG
        temp = "scenes.scene_1.script.MoveEast('BlackQueen')"
        FUNCTION = 1
CALLBACK FUNCTION ButtonSouthCallback() AS LONG
        temp = "scenes.scene_1.script.MoveSouth('BlackQueen')"
        FUNCTION = 1
CALLBACK FUNCTION ButtonWestCallback() AS LONG
        temp = "scenes.scene_1.script.MoveWest('BlackQueen')"
        FUNCTION = 1
' Main
  FUNCTION PBMAIN
     LOCAL hInst AS DWORD
     LOCAL hr AS DWORD
     LOCAL OcxName AS ASCIIZ * 255
     LOCAL pUnk AS DWORD
     LOCAL vVar AS VARIANT
     LOCAL vIdx AS VARIANT
     LOCAL uMsg AS tagMsg
     LOCAL dwCookie AS DWORD
     OcxName = "DXStudioPlayerDLL.DXStudioPlayer.1"
    ' OcxName must be formatted in one of the following ways:
    ' ·  A ProgID such as "MSCAL.Calendar.7"
    ' ·  A CLSID such as "{8E27C92B-1264-101C-8A2F-040224009C02}"
    ' ·  A URL such as "http://www.microsoft.com"
    ' ·  A reference to an Active document such as "file://\\Documents\MyDoc.doc"
    ' ·  A fragment of HTML such as "MSHTML:<HTML><BODY>This is a line of text</BODY></HTML>"
    ' Note   "MSHTML:" must precede the HTML fragment so that it is designated as being an MSHTML stream.
     hInst = GetModuleHandle(BYVAL %NULL)
     AtlAxWinInit   ' // Initializes ATL
     DIALOG NEW 0, "Test DX Studio",,, 800, 600, %WS_OVERLAPPEDWINDOW, 0 TO hDlg
     CONTROL ADD "AtlAxWin", hDlg, %ID_OCX, OcxName, 0, 0, 550, 550, %WS_VISIBLE OR %WS_CHILD
     CONTROL ADD BUTTON, hDlg, %ID_NORTH, "North", 634, 143, 75, 25, , , CALL ButtonNorthCallback() ' Use default styles
     CONTROL ADD BUTTON, hDlg, %ID_EAST, "East", 680, 196, 75, 25, , , CALL ButtonEastCallback() ' Use default styles
     CONTROL ADD BUTTON, hDlg, %ID_NORTH, "South", 634, 243, 75, 25, , , CALL ButtonSouthCallback() ' Use default styles
     CONTROL ADD BUTTON, hDlg, %ID_NORTH, "West", 582, 196, 75, 25, , , CALL ButtonWestCallback() ' Use default styles
     CONTROL ADD BUTTON, hDlg, %ID_RESET, "Reset Pieces", 634, 327, 85, 25, , , CALL ButtonResetCallback() ' Use default styles
     CONTROL HANDLE hDlg, %ID_OCX TO hOcx
     AtlAxGetControl(hOcx, pUnk)
     AtlMakeDispatch(pUnk, vVar)
     SET oOcx = vVar
     vVar = "F:\PowerBasicClassicWindows9\Chessboard.dxstudio"
     OBJECT LET oOcx.src = vVar
     OBJECT CALL oOcx.ManualInit
     temp = 0
     OBJECT LET oOcx.ManualCreateAndUpdate = temp
     DIALOG SHOW MODAL hDlg, CALL MainDlgProc TO hr
  Terminate:
     AtlAxWinTerm   ' // Uninitializes ATL
     SET oOcx = NOTHING
