A must
Started by Gian Kolbjornsen, May 27, 2004, 05:02:14 AM
Gian Kolbjornsen
Hi,
In environment options it should be possible to turn on autosave and set the interval. By default I would set it to be enabled and set to 5 minutes.
Gian
Anonymous
I thought FireFly auto-saved anyway? For sure if you add some code to a module or form and then close the form those changes get saved without any prompting. That's good enough for me.
Andrew
Environment Options has an option to automatically save Projects when you exit. However, like Gian suggests, a timed saved would be beneficial - especially in cases where the computer crashes or something screws up.
