Question : an example of eventcode for one option button
Started by Stephane Fonteyne, October 22, 2011, 08:50:41 AM
Stephane Fonteyne
Dear Support,
1.) When I click the button "Read" of the option button the program in running is crashed. What is the reason and how can I an solution for that software problem?
Can somebody help me what I can do?
2.) I would like to need an example that used option buttons in an event procedure.
Function FORM1_BTNREAD_BN_CLICKED ( _
      Local read_data As Long : read_data = 0
      'read_data = dll_Read(adres)
      FF_ListBox_AddString(HWND_FORM1_LSTMOTORBOXSTATUS,"Read: " & Str$(read_data) & $CrLf)
      Do While(read_data <> 65)
         FF_ListBox_AddString(HWND_FORM1_LSTMOTORBOXSTATUS,"Read in the loop: " & Str$(read_data) & $CrLf)
         If((FF_Control_GetOption(HWND_FORM1_OPTREADED) = 1)) Then
            FF_Control_SetOption(HWND_FORM1_OPTREADED,IDC_FORM1_OPTREADED,IDC_FORM1_OPTREADED,0)
         Else
            FF_Control_SetOption(HWND_FORM1_OPTREADED,IDC_FORM1_OPTREADED,IDC_FORM1_OPTREADED,1)
      Loop
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
James Padgett
#1
FF_Control_SetOption  form , firstoptionbutton, lastoptionbutton, optionbutton to set
Your last param is 0 and should be the option button you want to set .
But you indicate you only have one option button.... option buttons are toggles and one must be selected
so if you only have one then there is no need to set it .. once active it will always be set ..
Stephane,
you could set the state of an optionbutton with the CheckDlgButton function.
Use the following code:
CheckDlgButton(HWND_FORM1, IDC_FORM1_OPTREADED, 0) 'Unchecked
or
CheckDlgButton(HWND_FORM1, IDC_FORM1_OPTREADED, 1) 'Checked
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
