Transparent Bitmaps and Gradient Backgrounds
Started by Richard Kelly, November 16, 2011, 09:11:18 AM
Richard Kelly
Here is what I've come up with to paint bitmaps on my FF forms with transparent backgrounds. I use a label control for the bitmap destination and in the forms CREATE I call the "SetTransparent" routine to be sure I get a null brush for the label control.
In the forms CUSTOM function:
Function MAIN_CUSTOM ( _
Local hBMColor          As Dword
   Select Case wMsg
    Case %WM_ERASEBKGND
        GradientPaint (hWndForm)
        hBMColor = LoadImage (App.hInstance,"IMAGE_CTARGET",%IMAGE_BITMAP,0,0,%LR_SHARED)
        TransparentBitmap (HWND_MAIN_CTLOGO,hBMColor,Rgb(34,177,76))
        DeleteObject hBMColor
        Function = %TRUE
        Exit Function
And the supporting routines:
Sub TransparentBitmap (ByVal hWndControl As Long, _
                       ByVal hPicture As Dword, _
                       ByVal nTransparentColor As Dword)
' Paint a bitmap with a transparent background
Local hDC               As Dword
Local hDCColor          As Dword
Local BMInfo            As Bitmap
' Get size of bitmap
    GetObject (hPicture,SizeOf(BMInfo),BMInfo)
' Get DC and set it to the loaded bitmap
    hDCColor = CreateCompatibleDC (0)
    SelectObject (hDCColor,hPicture)
' Get control's DC and paint bitmap
    hDC = GetDC (hWndControl)
    TransparentBlt (hDC,0,0,BMInfo.BMWidth,BMInfo.BMHeight,hDCColor,0,0,BMInfo.BMWidth,BMInfo.BMHeight,nTransparentColor)
' Cleanup
    DeleteDC hDC
    DeleteDC hDCColor
End Sub
Sub SetTransparent (ByVal hWndControl As Dword)
Local ff    As FLY_DATA Ptr
Local hDC   As Dword
    ff = GetProp (hWndControl, "FLY_PTR")
    @ff.hBackBrush = GetStockObject (%NULL_BRUSH)
    SetProp hWndControl, "FLY_PTR", ff
    hDC = GetDC(hWndControl)
    SetBkMode hDC, %TRANSPARENT
    ReleaseDC hWndControl, hDC
End Sub
Sub GradientPaint (ByVal hWndForm As Dword)
Local hDC            As Dword
Local rc             As Rect
Dim gRect            As GRADIENT_RECT
Dim vert(1)          As TRIVERTEX
    hDC = GetDC (hWndForm)
    GetClientRect (hWndForm,rc)
    vert(0).x      = 0
    vert(0).y      = 0
    vert(0).Red    = &HFF00
    vert(0).Green  = &HFF00
    vert(0).Blue   = &HFF00
    vert(0).Alpha  = &H0000
    vert(1).x      = rc.nRight
    vert(1).y      = rc.nBottom
    vert(1).Red    = &HE300
    vert(1).Green  = &HED00
    vert(1).Blue   = &HF900
    vert(1).Alpha  = &H0000
    gRect.UpperLeft  = 0
    gRect.LowerRight = 1
    GradientFill hDC, vert(0), 2, gRect, 1, %GRADIENT_FILL_RECT_V
    ReleaseDC hWndForm, hDC
End Sub
Attached is a sample of the result for the project (main form) I'm currently working on.
Rick Kelly
