XCOPY API
Started by Martin Francom, November 28, 2011, 12:44:16 AM
Martin Francom
Is there an API for XCOPY ?    Or other file copy routines accomplished with Jose' API ?
What I want to be able to do from my program without using Shell
is to be able to Copy files using wildcards  PB's FileCopy does not allow *.*
  ie: FileCopy  \MyFiles\*.*    \MyBackup
Is there an API method to copy files using wildcards?
Yes, using the CopyFolder or CopyFile methods of the FileSystemObject.
Read the following documentation:
CopyFolder method: http://msdn.microsoft.com/en-us/library/xbfwysex%28VS.85%29.aspx
CopyFile method: http://msdn.microsoft.com/en-us/library/e1wf9e7w%28VS.85%29.aspx
Example:
#COMPILE EXE
#DIM ALL
#INCLUDE ONCE "scrrun.inc"
FUNCTION PBMAIN () AS LONG
   LOCAL fso AS IFileSystem
   fso = NEWCOM "Scripting.FileSystemObject"
   IF ISOBJECT(fso) THEN fso.CopyFolder("c:\MyFiles\*", "c:\MyBackup\")
   ' -or-
   IF ISOBJECT(fso) THEN fso.CopyFile("c:\MyFiles\*.*", "c:\MyBackup\")
Wildcard characters can only be used in the last path component of the source argument.
You can check if there has been an error with OBJRESULT.
Martin Francom
#2
Thanks Jose'
I want to make PB functions that will return "Success" or "Failure"
Here's what I got. I must be doing some wrong.  ObjResult is = to -2146828230
Not sure what that means but the files are not being copied.
#COMPILE EXE
#DIM ALL
' For more information check
' http://msdn.microsoft.com/en-us/library/e1wf9e7w(v=VS.85).aspx
   LOCAL objF  AS STRING
   LOCAL destF AS STRING
   result AS LONG
   objF = "C:\Myfiles\*.bas"
   destF = "C:\MyBackup\"
   result = xCopyFile (objF, destF)
   MSGBOX "Done " & STR$(result)
FUNCTION xCopyFile (objFile AS STRING, destFile AS STRING) AS LONG
     IF ISOBJECT(fso) THEN fso.CopyFile(objFile, destFile)
     FUNCTION = OBJRESULT
FUNCTION xCopyFolder (objFolder AS STRING, destFolder AS STRING) AS LONG
     IF ISOBJECT(fso) THEN fso.CopyFolder(objFolder, destFolder)
FUNCTION xMoveFile (objFile AS STRING, destFile AS STRING) AS LONG
     IF ISOBJECT(fso) THEN fso.MoveFile(objFile, destFile)
as with xCopy  is there a way to add an argument the to copy ONLY IF NEWER  ?
#3
Quoteas with xCopy  is there a way to add an argument the to copy ONLY IF NEWER  ?
Yes, there is. In a DOS box (Command) put this command:
help xcopy and press ENTER
It will show you all parameters.
To copy only files that are newer use
xcopy /d /y source destination
This will overwrite files with newer versions only without asking.
Rolf
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Martin Francom
Ok figured out problem.  If file exists then it will NOT overwrite file and it give the error.
There's a overwrite argument I will add it.
Does the overwrite argument support  Overwrite if newer?
Martin Francom
Quote from: Rolf Brandt on November 28, 2011, 06:23:25 AM
Rolf
Thanks Rolf but I don't want to be shelling to xCopy  I would prefer to use the API function directly if possible.
Be aware that it only accepts 0 (false) or -1 (visual basic true). You should also change the AS STRING to AS WSTRING.
No.
Martin Francom
There must be a way to compare the file date of two files to determine which is newer.
Indeed. What there is not, as far as I know, is a function or method that does everything you want.
Martin Francom
Jose'   yes I understand THESE functions can't compare files dates
But there should be a way to write a diferent function that can compare
two files and determine which one is older.
So if you wanted to be able to programmatically compare two files and
determine which is older.   How would you do it.?
Are there any PB functions that can do that?
Or, maybe there is some WinAPI function that can determine which is the
older of two files?
Michael Stefanik
Quote from: Marty Francom on November 29, 2011, 02:51:38 AM
Using the Win32 API, you would use CreateFile to open the files in question, GetFileTime to get their last modification time, and CompareFileTime to compare the two values. Close the file handles when you're done.
Mike Stefanik
sockettools.com
Martin Francom
Thanks Mike,   I will give that a try.
Douglas McDonald
Marty,
Have you tried microsoft's RICHCOPY. As I understand it is a replacement for xcopy. I don't know if there is an API but you may want to take a look at it.
Just a thought
Doug
Doug McDonald
KD5NWK
www.redforksoftware.com
James Padgett
I think there is also  robocopy   a fairly powerful copy program...
