resource compiler error
Started by Wilko Verweij, December 20, 2011, 05:15:06 PM
Wilko Verweij
Hi,
I get an error I'm pretty sure was discussed before but I cannot find it. I picked up an old project (2009) which I succesfully converted to FF3 at that time (with PB9). I still have FF 3.1 and PB9. When I compile, I receive an error message because PBRES crashes without specific error information. Afterwards I receive an empty "Compile Results" balloon. What am I doing wrong? I remember all the graphic files (for toolbar, menu and program) should be in the release folder and that's where they are. So it must be something else. Any suggestions?
This is a strange error and it used to happen to me from time to time. If I remember correctly, I used to delete all of the code generation files CODEGEN_*.* and then restart FF and try compiling again. Most of the time I think that worked.
Wilko Verweij
Thanks for your fast response. I tried your suggestion but it didn't work. More suggestions, anyone?
Wilko
Check the contents of the .rc file. There must something wrong in it.
David Kenny
You may get more of an answer if you open the only ...Main.bas codgen file in PB Edit and compile from there.
Wilko Verweij
Quote from: Jose Roca on December 20, 2011, 06:47:25 PM
I tried to compile the .res file to a .pbr (from a DOS-box) and that worked fine, strange enough. So I guess it must be something else...
And for what you need a .pbr file? PB10 uses .res files directly.
FF3.5 uses the .res directly... the older 3.1 is what Wilko is using.
Wilko Verweij
Quote from: TechSupport on December 21, 2011, 06:08:40 PM
That's correct. I tried to compile the .res file to see if something was wrong with the .rc or .res. Apparently that's not the case.
