Problem with OCX control fixed by a messagebox.
Started by Elias Montoya, January 11, 2012, 04:38:39 PM
Elias Montoya
Im trying to fix BasictoPHP's DHTMLEdit support, because it doesn't work on windows 7. Easy stuff. However i am getting stuck with something that should be easy... and adding a simple message box fixes everything...
   Local Dh   As IDHTMLEdit
   Local sPar  As String
   Local wPar  As wString
   Local vPar  As Variant
   Dh = OC_GetDispatch(HWND_STEP10_OCXCONTROL1)
This doesn't work...
   If IsObject(Dh) Then
      sPar = "C:\Users\Diamante\Documents\test.html"
      vPar = sPar
      Dh.NewDocument
      Dh.LoadDocument vPar
      wPar = Only_Path(sPar)
      Dh.BaseURL = wPar
      dh.refresh
      Dh = Nothing
But this works just fine after closing the message box...
      vPar = sPar
      Dh.NewDocument
      MsgBox "ocus pocus"
      Dh.BaseURL = wPar
      dh.refresh
      Dh = Nothing
I must be doing something wrong. Any ideas what is it?  :o
Elias Montoya
Im sorry, im not sure this post goes here... it's not a firefly issue, but a question about my own code.
