Question about listviews and %WM_LBUTTONUP
Started by Elias Montoya, February 09, 2012, 08:35:37 PM
Elias Montoya
I cant get the %WM_LBUTTONUP event for single clicks in a listview, but i get them fine with double clicks. Like this:
Click [nothing]
Click [nothing] Click [%WM_LBUTTONUP]
How come?
do a search in the form for nm_click. That is  better choice for handling listview clicks.
Hello Elias,
I usually handle listview mouse events in the forms Custom Event (See code example). That works ok. There might of course be better solutions.
Function FRMRECCURRENT_CUSTOM ( _
   Local lpNmh  As NMHDR Ptr
   Local lpLvNm As NM_LISTVIEW Ptr
   Local lLvItem        As Long
   Local lLvSubItem    As Long
   Select Case wMsg
      Case %WM_NOTIFY
         lpNmh = lParam
         If @lpNmh.idFrom = IDC_FRMRECCURRENT_LISTVIEW1 Then
            lpLvNm = lParam
            Select Case @LpLvNm.hdr.Code
               Case %NM_DBLCLK   'left double-click
               Case  %NM_CLICK
               Case %NM_RCLICK
               Case Else
      Case Else
Rolf
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Elias Montoya
(W. C. Fields)
