Proposed changes and additions for version 1.05 of my headers
Started by José Roca, August 29, 2012, 05:06:53 PM
Changed the RPC_STATUS return value in the Rpc functions from DWORD to LONG, since the C++ headers define STATUS as LONG.
Removed a couple of conditions in the file esent.inc.
See: http://www.jose.it-berater.org/smfforum/index.php?topic=4562.msg17116#msg17116
New macro:
' Returns the largest integral value that is not greater than x.
' Can be used to emulate the C floor function.
MACRO AfxFloor(x) = INT(x)
In AfxWin.inc.
File: AfxWin.inc.
' Rounds a numeric value to a specified number of decimal places. Uses the "round up at
' five" approach instead of "banker's rounding".
' numDigits n is an  expression specifying the number of decimal places required in the result.
' AfxRound is especially useful in cases where you have a variable in Single, Double, or
' Extended-precision, and you want to put it into a Currency variable or display it, rounded
' to a specific number of decimal places.
' Note: PowerBASIC uses the IIEE standard for rounding. It is  is implemented by the "banker's
' rounding" principle: if the fractional digit being rounded off is exactly five, with no
' trailing digits, the number is rounded to the nearest even number.
' Unfortunately, in the business world nobody uses banker's rounding, not even the bankers.
' In the EU, the "round up at five" approach is mandatory by law. This makes all the
' functions/statements and numeric types that use banker's rounding useless for business
' applications in the EU.
FUNCTION AfxRound (BYVAL extValue AS EXT, BYVAL numDigits AS LONG) AS EXT
   LOCAL nMult AS LONG
   nMult = 10 ^ numDigits
   FUNCTION = FIX((nMult * extValue + (SGN(extValue)) * .5##)) / nMult
File: AfxFile.inc.
' Get file content type from file extension looking at the registry.
FUNCTION AfxGetContentTypeFromFileExt (BYVAL bstrExt AS WSTRING) AS WSTRING
   LOCAL hr       AS LONG
   LOCAL hKey     AS DWORD
   LOCAL wszBuff  AS WSTRINGZ * 1024
   IF LEFT$(bstrExt, 1) <> "." THEN bstrExt += "."
   IF RegOpenKeyExW(%HKEY_CLASSES_ROOT, BYCOPY bstrExt, 0, %KEY_QUERY_VALUE, hKey) = %ERROR_SUCCESS THEN
      IF hKey THEN
         ' // First look at the content type
         hr = RegQueryValueExW(hKey, "Content Type", 0, 0, wszBuff, SIZEOF(wszBuff))
         ' // If it fails, look at the default value
         IF hr <> %ERROR_SUCCESS THEN RegQueryValueExW(hKey, "", 0, 0, wszBuff, SIZEOF(wszBuff))
         RegCloseKey hKey
         wszBuff = EXTRACT$(wszBuff, CHR$(0))
   IF LEN(wszBuff) = 0 THEN wszBuff = "Unknown"
   FUNCTION = wszBuff
File: ListViewCtrl.inc.
' Retrieves the font used by the ToolTip control that the list-view control uses to display ToolTips.
FUNCTION LietView_GetTooltipsFont (BYVAL hwndLV AS DWORD) AS DWORD
   LOCAL hwndTooltips AS DWORD
   hwndTooltips = SendMessage(hwndLV, %LVM_GETTOOLTIPS, 0, 0)
   FUNCTION = SendMessage(hwndTooltips, %WM_GETFONT, 0, 0)
' Sets the font used by the ToolTip control that the list-view control uses to display ToolTips.
' Parameters:
' - hwndLV  = Handle to the ListView control.
' - hFont   = Handle to the font. If this parameter is NULL, the control uses the default system font to draw text.
' - fRedraw = Specifies whether the control should be redrawn immediately upon setting the font.
'             If this parameter is TRUE, the control redraws itself.
SUB ListView_SetTooltipsFont (BYVAL hwndLV AS DWORD, OPTIONAL BYVAL hFont AS DWORD, OPTIONAL BYVAL fRedraw AS LONG)
   SendMessage hwndTooltips, %WM_SETFONT, hFont, fRedraw
File: TooltipCtrl.inc
' Retrieves the handle of the font used by the ToolTip control.
FUNCTION Tooltip_GetFont (BYVAL hTooltip AS DWORD) AS DWORD
   FUNCTION = SendMessage(hTooltip, %WM_GETFONT, 0, 0)
' Sets the font used by the ToolTip control.
' Parameters:
' - hTooltip  = Handle to the ToolTip control.
SUB Tooltip_SetFont (BYVAL hTooltip AS DWORD, OPTIONAL BYVAL hFont AS DWORD, OPTIONAL BYVAL fRedraw AS LONG)
   SendMessage hTooltip, %WM_SETFONT, hFont, fRedraw
