Author Topic: XPButton issue  (Read 625 times)
Dan English
XPButton issue
« on: November 15, 2012, 04:52:13 PM »
I'm seeing unexpected behaviour involving an XPButton control.
Picture this -- I have a parent window with an XPButton that triggers a child window.  This child window is modally opened over top of the parent.  The child window contains a big listview control.  I have the listview's double-click event coded to close the child window (and return the clicked row's lParam).
So when I double-click the child window's listview control, the child gets closed as expected.  If it so happens that the mouse cursor's x/y co-ordinate is in the same x/y co-ordinate of the parent's XPButton dimensions, the child window appears again.  Basically, the parent XPButton's BN_CLICKED message is triggered again, thus opening up the child.
This doesn't happen if I double-click the child listview over top of a normal command button on the parent.
Has anyone seem something like this, and know how I can stop the behaviour?
Re: XPButton issue
« Reply #1 on: November 16, 2012, 08:09:49 AM »
Seems pretty odd. Maybe you can disable the button just prior to displaying your popup Form and the re-enable it once that Form closes. The XP Button is Jose's. Not sure if he is investigating the issue.
Re: XPButton issue
« Reply #2 on: November 16, 2012, 11:13:55 AM »
Maybe the parent window is being re-enabled too early, or something else. (code not shown). If it fires it is because the program is sending a BN_CLICKED message to it. The part of the program that sends that message is the one to inspect.
This test works fine:
#COMPILE EXE
#DIM ALL
%UNICODE = 1
' // Include files for external files
%USEXPBUTTON = 1
#INCLUDE ONCE "CWindow.inc"        ' // CWindow class
#INCLUDE ONCE "ListViewCtrl.inc"   ' // ListView control wrapper functions
%IDC_POPUP = 1001
%IDC_LISTVIEW = 1002
' Main
FUNCTION WinMain (BYVAL hInstance AS DWORD, BYVAL hPrevInstance AS DWORD, BYVAL lpszCmdLine AS WSTRINGZ PTR, BYVAL nCmdShow AS LONG) AS LONG
   ' // Set process DPI aware
   IF AfxGetWindowsVersion => 6 THEN SetProcessDPIAware
   LOCAL pWindow AS IWindow
   pWindow = CLASS "CWindow"
   IF ISNOTHING(pWindow) THEN EXIT FUNCTION
   ' // Create the main window
   ' // Note: CW_USEDEFAULT is used as the default value When passing 0's as the width and height
   pWindow.CreateWindow(%NULL, "CWindow with an XPButton", 0, 0, 500, 350, 0, 0, CODEPTR(WindowProc))
   ' // Center the window
   pWindow.CenterWindow
   ' // Add buttons
   pWindow.AddXPButton(pWindow.hwnd, %IDC_POPUP, "&Popup", 250, 250, 75, 23)
   pWindow.AddXPButton(pWindow.hwnd, %IDCANCEL, "&Close", 350, 250, 75, 23)
   ' // Default message pump (you can replace it with your own)
   pWindow.DoEvents(nCmdShow)
' Main callback function.
FUNCTION WindowProc (BYVAL hwnd AS DWORD, BYVAL uMsg AS DWORD, BYVAL wParam AS DWORD, BYVAL lParam AS LONG) AS LONG
   STATIC hInstance AS DWORD        ' // Instance handle
   STATIC lpc AS CREATESTRUCT PTR   ' // Pointer to the creation parameters
   STATIC pWindow AS IWindow        ' // Reference to the IWindow interface
   SELECT CASE uMsg
      CASE %WM_CREATE
         lpc = lParam
         hInstance = @lpc.hInstance
         ' // Get a reference to the IWindow interface from the CREATESTRUCT structure
         pWindow = CWindow_GetObjectFromCreateStruct(lParam)
      CASE %WM_COMMAND
         SELECT CASE LO(WORD, wParam)
            CASE %IDCANCEL
               ' // If the Escape key has been pressed...
               IF HI(WORD, wParam) = %BN_CLICKED THEN
                  ' // ... close the application by sending a WM_CLOSE message
                  SendMessage hwnd, %WM_CLOSE, 0, 0
            CASE %IDC_POPUP
               PopupDialog(pWindow)
      CASE %WM_DESTROY
         ' // End the application
         PostQuitMessage 0
   ' // Pass unprocessed messages to Windows
   FUNCTION = DefWindowProc(hwnd, uMsg, wParam, lParam)
' Popup dialog
SUB PopupDialog (BYVAL pParentWindow AS IWindow)
   LOCAL pPopup AS IWindow
   pPopup = CLASS "CWindow"
   IF ISNOTHING(pPopup) THEN EXIT SUB
   LOCAL hwnd AS DWORD
   hwnd = pPopup.CreateWindow(pParentWindow.hwnd, "Popup dialog", 0, 0, 500, 350, _
          %WS_VISIBLE OR %WS_CAPTION OR %WS_POPUPWINDOW, %WS_EX_WINDOWEDGE, _
          CODEPTR(PopupWindowProc))
   pPopup.CenterWindow
   ' // Add a ListView control
   LOCAL hListView AS DWORD
   hListView = pPopup.AddListView(hwnd, %IDC_LISTVIEW, "", 5, 5, pParentWindow.ClientWidth - 10, pParentWindow.ClientHeight - 10)
   ' // Add some extended styles
   LOCAL dwExStyle AS DWORD
   dwExStyle = ListView_GetExtendedListViewStyle(hListView)
   dwExStyle = dwExStyle OR %LVS_EX_FULLROWSELECT OR %LVS_EX_GRIDLINES
   ListView_SetExtendedListViewStyle(hListView, dwExStyle)
   ' // Add the header's column names
   LOCAL i AS LONG
   FOR i = 0 TO 4
      ListView_AddColumn(hListView, i, "Column" & STR$(i), 110)
   ' // Populate the ListView with some data
   FOR i = 0 to 29
      ListView_AddItem(hListView, i, 0, "Column 0 Row" + STR$(i))
      ListView_SetItemText(hListView, i, 1, "Column 1 Row" + STR$(i))
      ListView_SetItemText(hListView, i, 2, "Column 2 Row" + STR$(i))
      ListView_SetItemText(hListView, i, 3, "Column 3 Row" + STR$(i))
      ListView_SetItemText(hListView, i, 4, "Column 4 Row" + STR$(i))
   ' // Select the fist item
   ListView_SelectItem hListView, 0
   ' // Set the focus in the ListView
   SetFocus hListView
   pPopup.DoEvents
' Editor options callback function.
FUNCTION PopupWindowProc (BYVAL hwnd AS DWORD, BYVAL uMsg AS DWORD, BYVAL wParam AS DWORD, BYVAL lParam AS LONG) AS LONG
   LOCAL  pnmhdr AS NMHDR PTR
   SELECT CASE uMsg
      CASE %WM_CREATE
         ' // Disable the owner of the modal window
         EnableWindow GetWindow(hwnd, %GW_OWNER), %FALSE
      CASE %WM_COMMAND
            CASE %IDCANCEL
      CASE %WM_SIZE
         ' // Resize the ListView control and its header
         IF wParam <> %SIZE_MINIMIZED THEN
            hListView = GetDlgItem(hwnd, %IDC_LISTVIEW)
            pWindow.MoveWindow hListView, 5, 5, pWindow.ClientWidth - 10, pWindow.ClientHeight - 10, %TRUE
      CASE %WM_NOTIFY
         pnmhdr = lParam
         SELECT CASE @pnmhdr.idFrom
            CASE %IDC_LISTVIEW
               SELECT CASE @pnmhdr.code
                  CASE %NM_DBLCLK
      CASE %WM_CLOSE
         ' // The owner window is enabled in WM_CLOSE rather than WM_DESTROY to
         ' // prevent the application from losing the focus. In WM_DESTROY the
         ' // modal window has already been removed from the screen by the system.
         ' // Because the remaining windows are disabled, the system gives the
         ' // focus to another application.
         EnableWindow GetWindow(hwnd, %GW_OWNER), %TRUE
      CASE %WM_DESTROY
         ' // Close the main window
         PostQuitMessage 0
Dan English
Re: XPButton issue
« Reply #3 on: November 16, 2012, 12:31:47 PM »
Hmm, in the child window (where the double-click event is processed), I don't believe I'm doing anything crazy.  Here's my code that sets a textbox, then closes the form:
Function FORM1_CUSTOM ( _
    Local pNMLV As NM_LISTVIEW Ptr
    Select Case wMsg
        Case %WM_NOTIFY
            pNMLV = lParam
            Select Case @pNMLV.hdr.idfrom
                Case IDC_FORM1_LISTVIEW1        ' notify message from the listview control
                    Select Case @pNMLV.hdr.Code
                        Case %NM_DBLCLK   'left double-click
                            ' Send selected value to target control, and close selector
                            FF_TextBox_SetText(gTargetHwnd, Trim$(FF_ListView_GetItemText(HWND_FORM1_LISTVIEW1, @pNMLV.iItem, 0)))
                            FF_CloseForm hWndForm
Is there maybe a better way to deal with double-clicking a listview?
Re: XPButton issue
« Reply #4 on: November 16, 2012, 01:19:16 PM »
Are you using the latest version of the headers?
Dan English
Re: XPButton issue
« Reply #5 on: November 16, 2012, 01:40:27 PM »
I'm fairly certain I've got the latest headers... all the .inc files are dated August 3, 2012 12:00 AM.
Re: XPButton issue
« Reply #6 on: November 16, 2012, 02:32:29 PM »
I wonder if it is related to closing the Form while you are still inside the Listview double click notification.....
Maybe under %NM_DBLCLK try a PostMessage to the Form using a user defined message (catch it via the CUSTOM) handler. Try setting your textbox value and closing the Form from that handler.
Something along these lines:
%MSG_USER_CLOSEFORM = %WM_USER + 100
                 PostMessage hWndForm, %MSG_USER_CLOSEFORM, 0, 0
Case %MSG_USER_CLOSEFORM
« Last Edit: November 16, 2012, 02:36:44 PM by TechSupport »
Dan English
Re: XPButton issue
« Reply #7 on: November 16, 2012, 02:48:26 PM »
Thanks Paul, but that doesn't seem to eliminate the issue.
I was able to implement your idea, and confirmed the necessary code path was followed, but the child form still pops up.
