Listview, Imagelists and DPI Scaling
Started by Richard Kelly, December 09, 2012, 08:11:57 AM
Richard Kelly
I have a listview that I've attached an imagelist to and when I load the listview I have logic that puts the image on a row if one is needed.
What technique is recommended so that my images scale to the current DPI setting?
This is what I'm currently doing, although the icon color as it's being shown on the listview is not correct and I've still to figure that one out.
        gImageList = ImageList_Create (32, 32, %ILC_MASK Or %ILC_COLOR32, 1, 0)
        ImageList_SetBkColor gImageList, %CLR_NONE
        hImage = LoadImage(app.hInstance,"IMAGE_LOCK", %IMAGE_ICON, 32, 32, 0)
        ImageList_ReplaceIcon gImageList, -1, hImage
        DeleteObject hImage
I have, for now, temporarily patched things up by having a 16, 24 and 32x32 size of listview image and used the following kludge:
        pWindow = Class "CWindow"
        If IsObject(pWindow) Then
            Select Case pWindow.DPI
                Case < 120
                    gImageList = ImageList_Create (16, 16, %ILC_MASK Or %ILC_COLOR32, 1, 0)
                    hImage = LoadImage(app.hInstance,"IMAGE_LOCK16", %IMAGE_BITMAP, 16, 16, %LR_DEFAULTCOLOR)
                    ImageList_Add gImageList, hImage, 0
                Case <  144
                    gImageList = ImageList_Create (24, 24, %ILC_MASK Or %ILC_COLOR32, 1, 0)
                    hImage = LoadImage(app.hInstance,"IMAGE_LOCK24", %IMAGE_BITMAP, 24, 24, %LR_DEFAULTCOLOR)
                Case Else
                    hImage = LoadImage(app.hInstance,"IMAGE_LOCK32", %IMAGE_BITMAP, 32, 32, %LR_DEFAULTCOLOR)
            pWindow = Nothing
            DeleteObject hImage
Rick Kelly
