Author Topic: Ztrace  (Read 466 times)
Douglas McDonald
  • PB, FF3,VB6 , B4A, Proton PDS, Mikroe Basic
    • RedforkSoftware,LLC
Ztrace
« on: January 28, 2013, 03:47:32 PM »
I know Ztrace is not really a part of FF  but maybe I can get an answer. Does ztrace have a problem with types or vars assigned from types?
'Type Test_struct
'    StepNr As String * 10
'    Relay As Relays
'    AD   As ADC
'End Type
        ts(j-1).StepNr = testX(j,0) 'get Realys
doesn't      ztrace ts(j-1).StepNr
 works       ? ts(j-1).StepNr
if I put it in a temp var:
dim temp as string
      temp = ts(j-1).StepNr
doesn't      ztrace temp
 works       ? temp
the same thing goes for  Ztrace str$(xyz.some_Long) doesn't work
ztrace "xzy" ok
ztrace str$(some_number) ok
Is there any documentation on ztrace? I'll look again on Jose's site
Thank you
Doug
Doug McDonald
KD5NWK
www.redforksoftware.com
Eddy Van Esch
    • DevOTechS
Re: Ztrace
« Reply #1 on: January 28, 2013, 03:59:47 PM »
Doug,
This works for me in FF 3.62:
Function FORM1_IMAGEBUTTON1_BN_CLICKED ( _
zTrace Str$(hWndControl)
zTrace Str$(hWndControl) + Str$(hWndForm)
I remember though that zTrace (once) used to require an ASCIIZ string as an argument.
Eddy
Eddy Van Esch
    • DevOTechS
Re: Ztrace
« Reply #2 on: January 28, 2013, 04:08:15 PM »
Ah, just noticed you wanted variables from types.
That works too:
'Type TestType Dword
'  a As Integer
'  b As Long
'End Type
Dim abcd(4) As TestType
abcd(1).b = -34
MsgBox(Str$(abcd(1).b))
zTrace Str$(abcd(1).b)
Eddy
Douglas McDonald
Re: Ztrace
« Reply #3 on: January 28, 2013, 04:49:15 PM »
Ok thank I must have something strange going on here. I'll re-download the latest ztrace.
Thank you
Doug McDonald
KD5NWK
Douglas McDonald
Re: Ztrace
« Reply #4 on: January 28, 2013, 05:08:28 PM »
 I'm using ztrace ver 1.52. It looks like you still have to use asciiz strings
zTrace 1.52
Is a small Win32 SDK DLL to display debugging information into a popup window tool, and/or a text file.
zTrace uses a distinct thread to work in parallel of the current application you want to debug.
zTrace is very useful at development time to check whether a program operates properly, it has been modeled onto the WinDev's Trace API.
Declaration:
DECLARE FUNCTION zTrace LIB "zTrace.DLL" ALIAS "zTrace" (zMessage AS ASCIIZ) AS LONG
DECLARE FUNCTION zDebug LIB "zTrace.DLL" ALIAS "zDebug" (zMessage AS ASCIIZ) AS LONG
Syntax to use:
zTrace("StringInformation")
zDebug("StringInformation")
I'll have to try your code samples and see whats going on.
Thank you
Doug McDonald
KD5NWK
