Author Topic: DateTimePicker question  (Read 588 times)
Sergio Tallone
  • Little Newbie
« on: March 06, 2013, 12:46:46 PM »
Good morning to all,
if possible I would like to know how can I read the notification message DTN_CLOSEUP% using a DateTimePicker control type. I tried in vain to use the FORM1_DATETIMEPICKER1_CUSTOM() function but obviously I'm doing something wrong (the same code works when used in a standard DDT dialog callback). Below is my sample code
FUNCTION FORM1_DATETIMEPICKER1_CUSTOM ( _
                                      ControlIndex  AS LONG,  _  ' index in Control Array
                                      hWndForm      AS DWORD, _  ' handle of Form
                                      hWndControl   AS DWORD, _  ' handle of Control
                                      wMsg          AS LONG,  _  ' type of message
                                      wParam        AS DWORD, _  ' first message parameter
                                      lParam        AS LONG   _  ' second message parameter
                                      ) AS LONG
   LOCAL pNmDt    AS NMDATETIMECHANGE PTR
   if  wMsg =  %WM_NOTIFY then
      pNmDt = lParam
      if  @pNmDt.hdr.code = %DTN_CLOSEUP then
        ztrace "Ok!"
Thanks
Sergio
Rudolf Furstauer
Re: DateTimePicker question
« Reply #1 on: March 06, 2013, 02:08:18 PM »
You can use the notification on the form:
Function FORM1_CUSTOM ( _
    Local hdrX As NMDATETIMECHANGE Ptr
   Select Case wMsg
      'Use this to detect changes in the calendar
      Case %WM_Notify
         hdrX = lParam
        'Get selected date/time
        Select Case @hdrX.hdr.idfrom
            Case IDC_FORM1_DATETIMEPICKER1
                Select Case @hdrX.hdr.Code
                    Case %DTN_DATETIMECHANGE
                        dp_("%DTN_DATETIMECHANGE")
                    Case %DTN_CLOSEUP
                        dp_("%DTN_CLOSEUP")
Rudolf Fuerstauer
Sergio Tallone
  • Little Newbie
« Reply #2 on: March 07, 2013, 04:25:06 AM »
Rudolf,
 thanks for your reply. I thought the best way to catch the notify messages of the datetimepicker control, was his custom function
bye
Sergio
