Header text on "tab control" not readable at high DPI setting (150 ppp)
Started by Jean-pierre Leroy, April 09, 2013, 11:19:31 AM
Jean-pierre Leroy
The header text on "tab control" is not readable at high DPI setting (150 ppp).
See the enclosed screenshots with my settings.
Can you please fix it ?
Jean-Pierre
Eddy Van Esch
Jean-Pierre,
Try changing some properties of the tab control :
- TabHeight
- HeaderTopPadding
Eddy
Thanks Jean-Pierre, looks like I was not adding scaling to the code generation for TabCtrl_SetItemSize and TabCtrl_SetPadding. I made a quick change to the code generation. Please try the attached new EXE and let me know if it works. Thanks!
[attachment deleted by admin]
Jean-pierre Leroy
Thanks a lot Paul,
It works perfectly now ... we can see the difference below:
