How can I initialize the combox if I start my project with default value
Started by Stephane Fonteyne, September 24, 2013, 08:16:38 AM
Stephane Fonteyne
Dear support,
I don't find the FF function for ComboBox for initialize the value with an highlight default when start the application
I see now when start the application all the four combobox are empty. I want to see that when I started the application default values highlight in the combobox
cboBaud  = 9600
cboParity = N
cboData  = 8
cboStop  = 1
I see this :
cboBaud  = " "
cboParity = " "
cboData  = " "
cboStop  = " "
Function FORM1_CBOBAUDRATE_CBN_SELCHANGE ( _
                                         idComboBox    As Dword  _  ' identifier of combobox
    Local index As Long
    index = FF_ComboBox_GetCurSel(HWND_FORM1_CBOBAUDRATE)
    g_strBaud = FF_ComboBox_GetText(HWND_FORM1_CBOBAUDRATE, index)
    MsgBox g_strBaud
Function FORM1_CBOPARITY_CBN_SELCHANGE ( _
    Local index As Long
    index = FF_ComboBox_GetCurSel(HWND_FORM1_CBOPARITY)
    g_strParity = FF_ComboBox_GetText(HWND_FORM1_CBOPARITY, index)
Function FORM1_CBODATABITS_CBN_SELCHANGE ( _
    Local index As Long
    index = FF_ComboBox_GetCurSel(HWND_FORM1_CBODATABITS)
    g_strDataBits = FF_ComboBox_GetText(HWND_FORM1_CBODATABITS, index)
Function FORM1_CBOSTOPBITS_CBN_SELCHANGE ( _
    Local index As Long
    index = FF_ComboBox_GetCurSel(HWND_FORM1_CBOSTOPBITS)
    g_strStopBits = FF_ComboBox_GetText(HWND_FORM1_CBOSTOPBITS, index)
Global g_strBaud        As String
Global g_strParity      As String
Global g_strDataBits    As String
Global g_strStopBits    As String
Function FORM1_WM_CREATE ( _
    'Private Sub form_load()
    '    Dim String_Comm As String
    '    Dim i As Integer
    '    Call init_com_param
    '    String_Comm = "," & Vitesse.Text & "," & Parite.Text & "," & Taille.Text & "," & BitStop.Text
    '    i = OPENCOM("COM2" & String_Comm) ' OPENCOM("COM2,2400,N,8,1")
    '    If i = 0 Then
    '        i = OPENCOM("COM1" & String_Comm) ' OPENCOM("COM1,2400,N,8,1")
    '        Option1.Value = True
    '    End If
    '    If i = 0 Then MsgBox ("COM Interface Error")
    '    'init
    '    TXD 1
    '    RTS 1
    '    DTR 1
    '    TIMEINIT
    'End Sub
    Local strCom As String
    Local i As Integer
    KillTimer(HWND_FORM1,IDC_FORM1_TIMER1)
    KillTimer(HWND_FORM1,IDC_FORM1_TIMER2)
    KillTimer(HWND_FORM1,IDC_FORM1_TIMER3)
    'Init_Com_Param()
    StrCom = "," & g_strBaud  & "," & g_strParity & "," & g_strDatabits & "," & g_strStopBits
    'i = Open_SerialPort("COM2" & strCom)
    If i = 0 Then
        FF_Control_SetOption(HWND_FORM1_OPTCOM1, IDC_FORM1_OPTCOM1, IDC_FORM1_OPTCOM2, IDC_FORM1_OPTCOM1)
        'i = Open_SerialPort("COM1" & strCom)
    If(i = 0) Then MsgBox("COM Interface Error")
    'TXD_out(1)
    'RTS_out(1)
    'DTR_out(1)
    'Time_Init()
I try this for init but doesn't work
Sub Init_Com()
    FF_ComboBox_SetCurSel(HWND_FORM1_CBOBAUDRATE, 6)
End Sub
Can someone help me in the right direction?
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
If you add your combobox strings using the "(Custom)" property in the "Properties" tab, then in order to set the default selected item you can change the value of the "InitialSelection" value also found on the "Properties" tab. By default, the "InitialSelection" property is -1 wheich means that nothing is selected.
To set the initial selection via code you would use the FF_ComboBox_SetCurSel function most likely in the WM_CREATE message handler.
Stephane Fonteyne
Quote from: TechSupport on September 24, 2013, 03:37:51 PM
Thanks Paul :=)
Stephane Fonteyne
