Split windows in code editor
Started by Eddy Van Esch, October 24, 2013, 08:50:21 AM
Eddy Van Esch
Another feature request.
The possibility to split windows in the FF code editor (horizontal and vertical) as in JellyFish.
From the JF help file:
JellyFish Pro can display the same edit document in up to four separate editing "panes". This is refered to as splitting the window.
To split a window you need to manually move the "splitter". The splitter can be found above the up arrow of the vertical scrollbar and to the left of the left arrow of the horizontal scrollbar. When you move your mouse over these areas you will notice that the cursor changes indicate that the window can now be split.
To begin the split, click and hold down the left mouse button and drag the splitter to the position you wish. You can resize the windows after they are position by simply resizing the edge of the window.
To remove a split window you can double-click on the edge of the split window, or simply drag the splitter to the edge of the screen.
Kind regards
Eddy
Wilko Verweij
Yes, I have this in my bug tracker to get done. I want this feature as well.
